Took the restrictor pill out
Old Jul 31, 2010, 05:48 PM
  #46
Djstorm100's Avatar
Number 15 is not optiomal at all
Old Sep 3, 2010, 08:45 AM
  #47
SiliconTek's Avatar
I have had my pill out for a few weeks now and all I can say is WOW! Car shifts so much more consistently and my 2nd and 3rd gear notchiness is totally gone, even with the cooler weather. It is really great not having to double clutch the tranny when it is cold anymore.
Old Sep 4, 2010, 06:30 AM
  #48
abazaba410's Avatar
N e one have it out for a few months/thousands of miles? Just curious long term if it still is holding up correctly.
Old Sep 21, 2010, 06:12 PM
  #49
joeystacoshack's Avatar
Anybody have any problems pop up from doing this mod?
Old Sep 21, 2010, 08:47 PM
  #50
linste's Avatar
does removing the pill affect the shifting? i heard it helps remove some of the griding/notchness
Last edited by linste; Sep 21, 2010 at 08:51 PM. Reason: edit. nvm i only read the first page.
Old Sep 22, 2010, 06:59 PM
  #51
Djstorm100's Avatar
It helps to save your clutch tahts for sure and its logic reasoning behind it as well. No problems as long as you are reving to 6k and dumping the clutch.
Old Mar 12, 2012, 05:31 PM
  #52
NateDaJew's Avatar
Took the pill out today. Thanks for the advice
Old Mar 16, 2012, 02:17 PM
  #53
kiddsm95's Avatar
Has anyone with the restrictor pill removed go in for warranty clutch work? Any problems with the warranty being voided?
Old Mar 16, 2012, 05:32 PM
  #54
Answer_1's Avatar
Unless they open the slave cylinder and see the missing restrictor, they won't know. Clutch is not warrantied anyways...
Old Mar 19, 2012, 09:55 AM
  #55
Pbayr0lla321's Avatar
Chances are they wouldn't notice this anyway . I can't imagine the tech getting on the phone with Mitsubishi and saying "Please void Mr.Smith's (insert VIN here) warrant because he's missing a spring"
And as stated above, chances are the clutch wouldn't be warrantied if a problem did arrise.
Old Mar 21, 2012, 05:40 PM
  #56
denlin68's Avatar
had a bmw 335i and it had the "Clutch Delay Valve" same thing as the "restrictor pill" ... Once I removed it from the 335i, like everyone said, clutch is so much better, and there is really no issues, I drove agressive and the clutch engagement was much better ! Now I am thinking about doing this to the EVO X
Any ideas on average how long it takes to remove the restrictor pill ? is it a easy DIY ?
Old Mar 21, 2012, 05:56 PM
  #57
kaczordd123's Avatar
I removed my pill the clutch was engaging low
And next day it got stiff and engages up high just like before
Old Mar 21, 2012, 07:18 PM
  #58
Answer_1's Avatar
Relatively easy DIY, takes like 30 minutes to one hour max to do.
Old Apr 4, 2012, 09:05 AM
  #59
Try rebleeding again. This may solve your problem.
Old Apr 5, 2012, 06:20 AM
  #60
Thumbs down
I bled it like 4 times and nothing it feels the same way it fif when i had the pill in any idea what could it be ?? I feel difference in engagment but it still grabs high as #%#k
Quick Reply: Took the restrictor pill out
