Clunk/Popping noise on startup
I searched high and low to see if anyone else had any similar issues and couldn't really find much. I am not talking about the noise that many hear when the car is put in reverse and begin backing out of driveway.
I had my car tuned yesterday at DG Motors on pump 93 and e85. Since leaving there, when i start my car i hear a quick clunking/popping noise coming from under the center console. This occurs for a split second right when the car cranks over. Sounds somewhat similar to the driveline clunk at high rpm shifts but seems to occur a little more toward the front of the car near the transmission. It is usually 2-3 clunks, and almost sounds like something is knocking on metal. I don't know if this is something i should be worried about, or if anyone might be able to help diagnose what is causing it.
Also, I can not tell definitely. But it seems like every now and then on downshifts it will also make the clunking noise when the clutch just starts to re-engage. Just a little harder to tell since the exhaust drones out the noise.
Hope someone might be able to lend some knowledge.
ctrenks
67
Mar 25, 2024 07:50 AM
damstr
30
Jul 23, 2008 10:53 AM
