400hp on stock turbo?
Old Aug 4, 2010, 08:30 PM
StealthIX's Avatar
is it possible to make 400hp on a stock turbo? im looking to tbe, intake, turbo inlet, intercooler with piping, and a tune or will i need to upgrade the turbo as well? i dont want to do E85, so thats not an option. thanks for the advice
Old Aug 4, 2010, 08:35 PM
BoostFTW05's Avatar
I made 400 on the Stock 8 turbo with 93 so yes I would say its possible for a X. I would say you would need to add cams and head studs to run a high spike, but other then that I would say yes. a 255 fuel pump also.
AC
Old Aug 4, 2010, 08:39 PM
lucas569's Avatar
Old Aug 4, 2010, 08:43 PM
StealthIX's Avatar
Originally Posted by lucas569
trust me ive looked through many threads before i posted my own, so theres no new to be the a smart a**
Old Aug 4, 2010, 08:45 PM
Drew_FL's Avatar
no
Old Aug 4, 2010, 08:47 PM
StealthIX's Avatar
Originally Posted by Drew_FL
no
no what?
Old Aug 4, 2010, 09:08 PM
murlo26's Avatar
On pump gas, absolutely not, you will never hit 400whp.
I broke 400whp on the stocker with E85, barely, but on pump gas won't happen.
Maybe if they change the dyno to read 400 sure, otherwise not a chance.
Old Aug 4, 2010, 09:29 PM
StealthIX's Avatar
but im looking to make 400hp not 400whp, for that i would have to upgrade the turbo
Old Aug 4, 2010, 09:30 PM
murlo26's Avatar
well 400hp, then sure, with all the bolt on's and a great tune on 93, you should be pretty close.
Don't do cams on the stock turbo...not needed.
Old Aug 4, 2010, 10:33 PM
jackygor's Avatar
Mind as well spend the money and get a turbo, less strain on your turbo as well as your engine.
Old Aug 4, 2010, 10:54 PM
Methodical4u's Avatar
yep, i've got the mods you have posted with the exception of the cams and got 330 awhp... so likely not.
Old Aug 5, 2010, 08:16 AM
DRAG's Avatar
Yes you can break 400 on race gas.
Old Aug 5, 2010, 05:11 PM
StealthIX's Avatar
dam only 330awhp? how much would that be in bhp?
Old Aug 5, 2010, 05:14 PM
StealthIX's Avatar
oh, but if i upgrade the turbo that mean i should do the fuel pump and injectors as well correct?
Old Aug 5, 2010, 06:45 PM
mlomker's Avatar
If you go with a Green then you'd be fine with just 800cc injectors.
Quick Reply: 400hp on stock turbo?
