Once again. bleeding the ACD on EVO X
So every search is saying mitsu has to do it?
I would like to know if anyone has found a way around this.
I have found a few things posted that look promising but unsure of the results.
https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/182155-bleeding-acd.html
(bleeding the ACD with just turning the key on and the pedal to the floor? evo 9 will it work on X)
my guess is "no" the system has change from the 9 to the 10 and with this so would the software.
i don’t remember the other post but it was about bleeding the system using a vacuum pump on the bleeder nip. Good idea but does it work?
I just got mine done at the dealership. Im sure there is a way to work around it without the scan tool, but i just felt more comfortable having it done the right way. It did cost $115 bones though.
I use a vacuum bleeder and feel that it work. I also bleed about a half a quart to play it safe, letting it sit over night and check the level tomorrow.
vince_w2004
14
Nov 15, 2010 12:30 AM
et98cav
Oct 12, 2010 06:56 PM
