how to bleed EVO X acd, noise from rear
First off, i am not much a forum typer so bare with me. I had my clutch install at a shop and they didn't bleed my ACD. My EVO X started to make a buzzing noise, from the acd/ayc pump at the rear.
Key on and pushing the gas method doesnt work to bleed the ACD on the EVO X. [actually, it does - Iowa999]
I had my EVo on a lift, use jack stand if not avalible. Make sure ACD/AYC fluid is full in the tunk. Have the car RUNNING in neutral with no parking brake on. Loosen the bleeder on the transfer case and rotate one of the wheels. When you rotate a wheel, the asc pump will kick on. Tighen the bleeder and refill the reservoir.
I alternated from wheel to wheel. Rotating the left front , will get the ACD/AYC pump running contiunously. Rotating/jerking the left rear wheel will also get the ACD/AYC pump going pretty good. I refilled the reservoir 3 times and the noise at the pump finally went away.
I put about 100 miles after the bleed, no buzzing noise at all comming from the pump or service lights.
First off, i am not much a forum typer so bare with me. I had my clutch install at a shop and they didn't bleed my asc. My EVO X started to make a buzzing noise, from the acd/ayc pump at the rear.
Key on and pushing the gas method doesnt work to bleed the asc on the EVO X.
I had my EVo on a lift, use jack stand if not avalible. Make sure asc fluid is full in the tunk. Have the car RUNNING in neutral with no parking brake on. Loosen the bleeder on the transfer case and rotate one of the wheels. When you rotate a wheel, the asc pump will kick on. Tighen the bleeder and refill the reservoir.
I alternated from wheel to wheel. Rotating the left front , will get the asc pump running contiunously. Rotating/jerking the left rear wheel will also get the asc pump going pretty good. I refilled the reservoir 3 times and the noise at the pump finally went away.
I understand it's the same pump, but different valves are used for the rear diff. Can you confirm that merely turning the steering wheel activates those valves? I would think that all the wheels would have to be rotating and then some having some steering input might do it.
After clutch installed, I had service light on....but method on top actually works...but make sure have four jack stand to do this job...anyway, take it to shop if u want to put aftermarket clutches.....the installation really sux and pain in ***!!... I will never going to do it again
How many times did you open and close the bleeder valve? Im getting 4wd service and asc service required lights after my whole drivetrain was taken apart and installed with new aftermarket clutch. And the level is way above the full mark in the reservoir now which i know is a distinct sign bleeding is needed. Any help is greatly appreciated.
Bumped for progress. I'll be trying this method either tonight or tomorrow. So far in my search, this is the only promising method to bleed the X acd without the tool.
