clutch-pedal height
Old Apr 29, 2012, 09:15 PM
Iowa999's Avatar
clutch-pedal height
My clutch pedal rests about 3/4" higher than the brake, which gets in the way of using the left foot to brake. Is there a simple way to lower the clutch pedal while still having the clutch disengage completely?
Old Apr 30, 2012, 05:33 AM
armysoldier1073's Avatar
on a oem cmc no... if you upgraded your cmc to a magnus there is some adjustability, but can only go so far before your clutch is slightly engaged even though it feels as though it is not.. if that makes any sense..
Old Apr 30, 2012, 06:45 AM
Iowa999's Avatar
That makes sense and is almost exactly what I didn't want to hear. But that's not your fault, so thanks. I might have to go with a very tall left foot-rest and retrain my leg.
Old Apr 30, 2012, 12:25 PM
or what might help, get some aftermarket pedals and see if you can make up the difference or close. if you tell them what your looking for they may be able to get you some custom ones. these are what most are using for aftermarket.
found these..
http://www.speedelement.com/index.ph...mart&Itemid=38
fugiwara
15
Mar 1, 2017 08:17 AM
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
DuBBzEvo27
Jun 16, 2014 09:58 PM
Lancerzz
13
Aug 4, 2013 04:25 PM
Z06Samuel
Nov 22, 2011 10:09 AM
Quick Reply: clutch-pedal height
