Mitsu change bottle for ATF SP III? (ACD Fluid)
The dealer gave me this for the AYC/ACD fluid. This used to come in a white bottle, now black? Just checking if I got the correct fluid from the dealer.
Was this before:
Was this before:
It's ATF-III
Automatic
Transmission
Fluid
III
Any Universal ATF with that spec or better (ATF-IV, V, etc) will work fine. It's not like it actually lubricates anything. It's just used as a hydrolic fluid that's pumped into the ACD to make it lock up. Hell, it's possible that you could put normal hydrolic fluid in it and it would be fine.
Automatic
Transmission
Fluid
III
Am I reading THIS right, it takes 7.5 quarts? Where is the drain/fill location?
FS[Northeast]: NJ;Buschur Racing DP(with o2 Bung for sideband)
ebadai98
Northeast Region
Aug 4, 2014 06:01 PM
