AMS TMP cams Idle RPM
Hey guys just installed my AMS TMP cams the other day just gotta put my trans back in tonight cause my rear main seal was leaking. So my question is what rpm should set my idle to on these?
I was thinking 900rpm
Thanks in advance for the input guys
You can raise your idle to 1000rpms, but I doubt its necessary. As AMS says the TMP's are in between the kelford b's and C's (just as my GSC s2's are) you should be able to get away with 850-900 if you are tuned properly. I am at 840rpms with big injectors and my GSC s2's. 1000rpms should be easy to dial in, 900 will take a bit more, 850 will take knowledge of the X
900rpm doesnt seem to bad
The_X_Effect
30
Aug 20, 2016 08:27 PM
FS[West]: Cosworth MX1 Cams w/3K miles
lbcevo
Oct 7, 2015 11:57 PM
