Compeition Clutch Twin Clutch pedal
I had my CC twin plate clutch installed last night and in doing so it was converted to push type.
Right now there is about 2 inches of free play at the top before the pedal gets a little stiffer. It pretty much has to go to the floor to completely release the clutch. When releasing the pedal it grabs the second I start to lift.
I was curious if there is a way to having it engage towards the top and then install a clutch stop so it's not pushed to far? Can this be done by doing the normal clutch pedal adjustment (turning the rod behind the clutch pedal?)
Thanks
Thanks
Thanks. I just realized if I use a pedal stop the engine probably won't start because the clutch isn't all the way in. Is there a way to disconnect that?
cbarno042
Sep 1, 2016 05:47 AM
Shastamiknasta
Dec 9, 2012 07:13 PM
