500whp goal !
500whp goal !
so ive been going some research and come to the conclusion that my hp goal is 500whp. mostly my evo will see street use, occasional track use. i dont want to make so much power that i will start braking **** like axles, diffs and all that.
i would like to know the requirments for 500whp. full engine build or just bottom end ? stage 3 clutch ? gtx 30 or gtx35, since fp black is long goneeee.
you can do full boltons and upgrade turbo and injectors and e85 and get 500whp easy don't know long it will last though im actually having my block built at ags autosports and ist costing me 4600 buck im shooting for 700whp
nice. are they good building motors ? im originally from jerzey so i dont know many shops down here in fl that are reputable. i moved down 3 years ago. and what does the 4600 include ? short block ? did you remove the engine and sent to them ready to build ? sorry for the questions but ive been doing some research on this too. i contacted ams and they gave me 6000 + for the bottom end build.
Ideally, a built bottom end is the way to go. The head can remain stock as long as you don't go over 8000rpm, you can actually use any Stage II cam with stock valve springs also.
Basically, after that you just need to run full bolt-ons (everything) and a solid turbo. The GTX35 will definitely get you there
Play it smart and just go big turbo right off the rip. Instead of making the typical guy move of buying a stock frame turbo, making close to, or at 500 and then realizing you want more. But your turbo is about to tap out soon... Then you'll need to sell the hot parts and the turbo to buy the kit. Just get a nice T3 kit and build the motor to hopefully avoid issues!
Hey bro just a update it actually cost me total of 6200 for the bottom end that blue printed sleeved piston rods lol dropped my car off a couple days ago to get stared with all parts turbo injectors fuel piping everything it was a total of 13000 you can do a turbo e85 injectors and get 500+whp just keep the torque under 400 and your good to go
I just installed an MHI 18K and will run that for at least a year but ATP GTX 3576 is something I'm considering for later. I want to keep the stock config/appearance, mani, etc for simplicity and stealth, don't need more than 500 WHP (E85) and like the spool of the 3576
