Evo X Surge while at constant throttle
Old Nov 23, 2014, 07:16 PM
CooperS7777's Avatar
I just picked up a 2008 MR and noticed after driving it for a bit that it seems to have a bit of a surge. Maintaining constant pedal position the car will fluctuate about 250 rpm. The car runs well (no misfires, codes etc.) and doesn't exhibit any other issues.
Car is on the stock tune, and is otherwise totally stock with the exception of a cat back, 75k miles on the clock.
Any thoughts? Im going to try a trans flush on Tuesday and see if that helps - Im not familiar with the SST yet but this seemed to be a the best place to start.
Old Dec 10, 2014, 02:31 PM
For others reference, a full trans flush and fresh filter solved this problem entirely.
Old Dec 25, 2014, 03:07 PM
NEpsiOver21's Avatar
Did you use the OEM tran fluid (diaqueen or whatever it's called) as well as OEM filter?
Old Dec 25, 2014, 03:40 PM
Diaqueen SSTF-I fluid and a SSP filter.
Old Dec 26, 2014, 05:56 PM
slvrevo84's Avatar
Thanks for the update!!
Old Dec 29, 2014, 08:18 AM
Thanks for the update indeed. Going to be flushing mine after winter as well.
ryukinevo
Nov 13, 2015 12:00 AM
jrblackSE
Sep 13, 2014 07:44 PM
JV21804
19
Oct 30, 2013 11:03 PM
boonkae
Mar 2, 2012 06:12 PM
Luffy
Oct 14, 2005 09:04 AM
Quick Reply: Evo X Surge while at constant throttle
