i just want a front axle seal replacement write up... why cant i find one...
Old Nov 24, 2015, 04:57 AM
iKENwin's Avatar
ok so I found that my front driver side axle seal is busted. im not entirely to sure how to replace it and I have had zero luck finding a write up on it in any forums. could anyone just give me the quick run down on how to do it? possibly pics? maybe a link on a "how to". im desperate.
Old Nov 24, 2015, 03:40 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Drain trans, remove axle with drain pan under trans to catch extra fluid, replace seal, reinstall axle, fill trans, clean up any spilled fluid. Maybe you should have a shop do it if you can't figure it out from here..
Old Nov 29, 2015, 10:30 AM
iKENwin's Avatar
Got everything pulled off just waiting on part. Do you know of any special way to press on seal? Anything special about reinstalling axle? Also why wouldnt i want to work on ky own vehicle ? Lol thanks for your input.
Old Nov 29, 2015, 07:26 PM
►EvolutionX◄'s Avatar
With a seal press kit, Or, if you have the CORRECT size socket, a socket and a hammer will suffice
Old Nov 30, 2015, 06:15 AM
splattj's Avatar
If you have one locally, the Harbor Freight seal press kit should do the job just fine without breaking the bank.
gearheadvr4
Lancer Tranny/Drivetrain Tech
Mar 16, 2016 10:38 PM
Lancer_Evo_8
Jun 20, 2015 06:39 AM
MitsuJoe
10
Oct 2, 2011 08:26 PM
Ralli04Art
Dec 15, 2005 06:24 AM
93civEJ1
Jun 5, 2005 08:04 PM
Quick Reply: i just want a front axle seal replacement write up... why cant i find one...
