Strange sound when turning the steering wheel
Hi everyone I just got a 08 ww evox base model. My car I noticed when turning the wheel most noticably at slow speed make a weird grinding sound like a cable being pulled is this normal.
Are you cranking the wheel all the way to wheel lock? Every car makes a noise if you are applying any pressure to the wheel when it's already at full lock. If this is not the case then I would get it looked at.
its def ur brake pads rubbin the rotors, time for new pads lol... does ur steering wheel vibrate when u stop? i jus changed my pads when i heard that noise and im all good now... could be a wheel bearing or a u joint also but id go wit ur pads first... hope this helps lemme kno!
It's really stange I tried leavign work going straigt fist and then turning at a slow speed and it still does this it's really weird and you can fell some kind of resistance and then after tat it's fine.
DarkEvo
Jun 9, 2012 08:23 AM
scottatyamaha
21
Oct 25, 2009 10:09 PM
tdanmorello
Lancer Troubleshooting
Mar 10, 2008 07:07 PM
