So i put the wrong fuel in today
was at a local gas station that ive never been to before because my fuel light was on.
every gas station i go to always has 93 on the right side of the buttons, but this one wanted to be different and switch it with 87.
Luckily i caught it before i filled my whole tank. 4 gallons got in. so i decided to put 4 gallons of 93 in and shift the car before 3k rpms until all the bad gas is out of the tank.
any other tips or suggestions would be awesome
Thanks,
Thanks,
yea it felt wierd accelerating so slow. thanks for the input guys.
im just gunna baby it until i refill.
make sure i double check everything now
You will be fine. If your engine starts to knock from the low octane fuel, the ECU will switch to a different timing / fuel map to protect the engine. This is all if you tuner kept the low octane timing / fuel map.
I would be nice to it for what you have left in your tank. If your Evo drinks gas like mine, it will only be about 75 miles anyway.
Unless you have a VERY aggressive tune, with your mods I think you will be fine, certainly if you stay under medium boost (20psi?). We California chumps live on 91 and can safely boost 26psi on a good, safe tune. Could ask your tuner as well to confirm.
At the time you filled up, sounds like you had a few gallons of 93 remaining in the car too. So the average octane of the mix you have in the car now should be ~91.5-91.8
