white smoke from vent?
i drove to and from work with no problem then i got in my car a few hours later and my windows were all fogged up didnt think much of it, but it got so bad i had to run the defrog to see out the window and doing so i can see like white smoke coming out so i switch it to the top vent and some white air started to come out but stopped after 2sec but contiuned to come out the windshield defog vent this is the 2nd time this happend to me any1 els have this problem?
it happened to me too... Stopped after a few seconds. Looked more like a mist rather then smoke. I remember it was super hot that day so I thought that might have something to do with it
Common when you have a good AC system.
You have humid air mixing with AC air with lower humidity, which makes it foggy. It only lasts a few seconds before the humidity normalizes. Nothing to be worried about.
^ this. But if it doesn't stop after couple minutes or if there's too much mist, u might have a leak n it will be pain to find it.....
Please don't freak him out. There's not a leak. It's normal. If there was a leak you'd know it - it'd be violent and wouldn't last very long. AC systems are under a TON of pressure.
Don't worry about it.
It doesn't happen often, but I've experienced the mist too, although not enough to cause the windows to fog. No issues with the a/c at all, still blows cold. I think it's normal.
JerseyEvo
23
Dec 23, 2006 10:01 PM
