K&N HP1010 or HP1004
fit wise for evo x, does anybody know which is a better k&n oil filter between HP1010 and HP1004?
i searched k&n's website and they listed HP1004 and searching the application guide for HP1010, it also listed the evo x.
i've never seen the two filters side to side with the factory MD356000.
thanks.
thanks.
Totally coincidental, but I was looking up the same thing for a customer today and saw the new listing.
I always use the 1004, but now I am curious as to the difference.
I will have both in stock tomorrow to compare.
I am sure both are good, but curious as to what the difference is.
HP-1004
Product Style: Oil Filters
Height: 3.41 in (87 mm)
Outside Diameter: 3.14 in (80 mm)
Thread Inside Diameter: M20 x 1.5-6H
PSI Relief Valve: 11-17
Anti Drain Back Valve: Yes
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
Weight: 0.6 lb (0.3 kg)
Product Box Length: 3.15 in (80 mm)
Product Box Width: 3.15 in (80 mm)
Product Box Height: 3.48 in (88 mm)
HP-1010
Height: 3.73 in (95 mm)
Outside Diameter: 2.69 in (68 mm)
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
Weight: 0.5 lb (0.2 kg)
Product Box Height: 3.75 in (95 mm)
Looks like the HP-1010 is just a bit bigger. We stock and sell the HP-1004.
Looks like either would be fine but HP-1010 might be closer to the stock size.
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
HP-1010
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
HP-1004
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
HP-1010
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
HP-1010
Style: Canister
Removal Nut: Yes
Bypass Valve: Yes
i used the HP1010 for my 4B12 when i had my GTS. If you didn't know the 4B12 is a 2.4L engine. I'm guessing the 1004 is made for the evo, not hp 1010
doing the math (assuming wall thickness is the same on both):
HP 1010: 21.198 in^3
HP 1004: 26.405 in^3
I'd go with the 1004, it's about 19.7% larger, volume-wise
1004 issues
i try 1004 KN today on my GSR evo x 2012 .... didn't work doesn't fit that is what the guy from Pep boy toll me and i have to buy the 1010 look small but he show me go just right and the 1004 was stuck
teamrevjohn
For Sale - Miscellaneous Automotive
Mar 13, 2013 09:25 AM
ayyofresh
For Sale - Wheels / Tires
13
Feb 20, 2012 05:20 PM
