Fast Key question
Fast Key question
Recently my fast key stopped working, my dash indicating a service was required for the key. I could only start the car by using the metal key with the fob attached to the back of the key.
The dealer then tried to reprogram the fast key. They had no trouble "re-registering" the key but could not get the fast key to register properly. I watched their little computer, connected tot he car, read out that it was trying to communciate and the progarmming was unsuccessful. We tried a new fast key too, to no avail. The net result is that they were not able to program the fast key and so I now start the car using the metal key. Anyone have similar experiences? The dealer indicated they had no idea why they coupld register teh key (the the car starts) but not set up the fast key program.
I had removed, recently, the Sirius module (just unplugged and unboled it from behind the dash), HVAC, and hazard switch in preparation for the cage install. I wouldn't have thought any of these modules were related to the FAST key, correct? is there a fast key module or piece of electronics that I may have disconnected? Thanks for the help.
I would re trace your previous steps when taking out those said parts. One by one and see if something changes. It seems to be the only thing that could have changed your fast key response. Did you have this problem prior or after the removal of those parts?
Thanks, After I removed the parts the problem arrived. You're right, of course, and my hope is that someone could tell me whether the FAST key system is dependent on any one module, or is it the ECU itself. Or, like you imply, that one of these other pieces (For example, Sirius) were key for the FAST key system to work...
I appreciate the input.
vizi0n
Lancer Troubleshooting
Oct 11, 2016 02:53 PM
gizmotoy
Sep 17, 2015 12:12 PM
pinegreen
15
Jul 25, 2014 04:28 PM
shadovarian
May 1, 2012 08:31 AM
