Chain Stretch Pics
Old May 28, 2011, 01:32 PM
UncleDonut's Avatar
Chain Stretch Pics
Just a couple of pics of my stretched timing chain. Bone stock 2008 EVO X with 50k miles. Tensioner extended fully and chain loose. I wonder how common this will be with these engines.
Attached Thumbnails Chain Stretch Pics-chain-stretch.jpg   Chain Stretch Pics-tensioner.jpg
Old May 28, 2011, 01:39 PM
sideway180sx's Avatar
i've seen quite a few evos and regular lancer with the 4b11 motor with the stretch chain.
Old May 28, 2011, 04:19 PM
luvboost's Avatar
not familiar with this at all. Can the car be driven like that?
Old May 28, 2011, 04:44 PM
UncleDonut's Avatar
It drove fine. When I parked it without the e-brake on the car rolled back in gear and it skipped a tooth. Then it wouldn't run at all.
Old May 28, 2011, 05:14 PM
malves85's Avatar
So whats the fix and how much? I imagine the chain itself is fairly cheap but the labor to fix might be a lot.
Old May 28, 2011, 05:34 PM
ilestjcollector's Avatar
went to a mitsu dealership for my SYSTEM SERVICE LIGHT last week... they checked it and i have a stretched timing chain. my car has 34k miles and im still waiting if the warranty will cover it!
Old May 28, 2011, 08:47 PM
ImEv0's Avatar
what are the symptoms of stretched chain?
wouldn't this be covered under power terrain?
Old May 29, 2011, 06:09 AM
usually a light will come on and tell you, but with a stretch chain the car with idle really rough or to the point where the car would not start. Yes the stretch chain will be cover under warranty unless you've done modification to the car.
Old May 29, 2011, 06:57 AM
ugakirk's Avatar
How much labor would be involved in this?
Old May 29, 2011, 10:02 AM
Windforce18's Avatar
Is this only with the 08's?
Old May 29, 2011, 10:17 AM
jdmEviL8's Avatar
^ its will all X's since they all use a timing chain...
and i would also like to see what the dealer will charge for this fix if you are not under warranty
Old May 29, 2011, 11:20 AM
i would say around $600 in labor.
Old May 29, 2011, 11:22 AM
you'll have to pull the valve cover , oil pan the the front timing cover off.
pretty much all the mitsubishi with the 4b1 motor, i've seen a few on the evos as well as the regular lancer.
Old May 29, 2011, 11:29 AM
Ltdanish07's Avatar
They should cover it. Mine went at 32k and it was covered. I only had an cat back exhaust though.
Old May 29, 2011, 11:51 AM
eg6motion's Avatar
crazy, not very high mileage for a CHAIN to stretch.
Quick Reply: Chain Stretch Pics
