Undertray removal
Undertray removal
Howdy all, quick question. Is removing the undertray annoying/difficult to do in any way? I'm curious what kind of effort I'm in for this weekend.
Do i need to lift the front end at all for this?
a lot of screws - you do need to lift the front end as you can't crawl in there or even reach all the screws.
i suggest you get some 2x12 (i made a cheesy ramp) and drive up on it - or you can just put jack stands for the fronts.
Lifting it up helps a lot, if your car is lowered there is no other way to do it as you wont be able to get all the crap out. I will suggest you to get yourself a flathead poker drive as well as a ratchet for the front bolts. I think i will order the SSP undertray next week and install it whenever it gets here. Tired of that plastic... and the damm push-in pins...
Thanks for the heads up.
I took a look under there this weekend and I wasn't sure which bolts / snaps need to be removed to get the entire thing off. Do i have to do the section where the oil is changed too, or are those just attached to the main undertray?
You can leave the access panels on there. They stay attached to the undertray.
Kreeker
16
Sep 22, 2015 08:03 AM
bpclements
Aug 28, 2004 09:27 PM
