Help: Build for Evo X. Feedback please?
Hey guys, so I'm going to be getting my Evo X soon and I plan to fix it up as soon as it's in my drive way. I've come up with some set up options for it just to start off. I was aiming for a 10 grand budget including the Dyno tune, but if I have to I would go over that
Here's what I got:
Turbo Kit
-Garret GTX3076R (0.94 A/R) - 788550-8 (Garrett Evo X Performance Kit)
-AMS Mitsubishi Lancer Evolution X 900XP Billet V-Band Turbo Kit -Ordering with cold air intake extension
Intercooler
-AGP FMIC and Hardpipes Package - EVO X
-AMS FMIC +LWIP w/ BOV +UIP
Clutch
-Stage 3 - Exedy Mitsubishi Lancer Evolution X Twin Metallic Clutch Kit
Chip
-Unichip Q+
??Turbo-Timer??--Should I get one?
Exhaust
-Buschur Racing Evo X 3" SS Dual Catback Exhaust w/ Bullet Muffler
Am I missing anything crucial?
Any feedback or suggestions on what I should do?, anything would be much appreciated.
Thanks,
Mario A.
Here's what I got:
Turbo Kit
Intercooler
Clutch
Chip
-Unichip Q+
Exhaust
Thanks,
Mario A.
Here's what I got:
Turbo Kit
Intercooler
Clutch
Chip
-Unichip Q+
Exhaust
Thanks,
Mario A.
Here's what I got:
Turbo Kit
Intercooler
Clutch
Chip
-Unichip Q+
Exhaust
Thanks,
Mario A.
Do NOT get that chip. You can't just chip an Evo. Get a Cobb Access port and a pro tune from someone that specializes in Evos.
You will need a minimum of 1000cc injectors. Look into the ID1000.
If you change clutch, you will need an upgraded Clutch Master Cylinder kit or you risk being stranded on the road when it blows.
You will need a 3 port boost solenoid to take full advantage of the parts.
Your stock cat will limit your power. Get a high flow cat or test pipe.
Turbo timer is not necessaary
AMS Mitsubishi Lancer Evolution X 900XP Billet V-Band Turbo Kit -Ordering with cold air intake extension - 5300 with CAI and recirculated BOV
AMS intercooler - 750
AMS LICP (UICP comes with the 900xp kit) - 350
Stage 3 Exedy clutch - 2000
Buschur Exhaust - 850
Test Pipe/High flow cat - 200/400
3port EBCS - 100
Installation for everything - at least 2500
That's 9550 without dyno/tune if you install yourself, and 12050+ if you have it done professionally. And you're probably missing the most important part -- tires to handle this power! Good 245/40/18's will be a grand, and more if you go wider.
The tune will run you another 500 give or take.
Expect to go over your budget...
3port EBCS - 100
Why are you getting two turbos? AMS kit comes with a turbo. You'll want the AMS 750XP kit as the smaller turbo is more suited for your stock block.
Yeah I wasn't too sure how that tuning went along, if I needed a chip or not, I'll just be getting the Cobb access port.
Will the 1000cc injectors still be needed for the 750XP? (Confused if that was for the two turbos)
For the 3 port solenoid I looked into the GM 3 port, seen some good feedback on other threads
Probably will go with the AMS Hight Flow Cat
Thanks a lot man
I was looking into which one I should get, but I think you made a very good point on getting the 750XP kit, so I'm probably going to go with that.
Thanks a lot man
Thanks a lot man
Thanks again, you've helped alot
Here's what I got:
Turbo Kit
Intercooler
Clutch
Chip
-Unichip Q+
Exhaust
Thanks,
Mario A.
Here's what I got:
Turbo Kit
Intercooler
Clutch
Chip
-Unichip Q+
Exhaust
Thanks,
Mario A.
Exedy is a good choice 1600.1000 for tuning/dyno + labor you should get out for less 10000 even if you don't do the Work yourself.Goodluck.
Just throwing this out there but a kinauguwa 25g is 950 and capable of over 500 whp billet wheel if you really want to do this on a budget pm I could get you to 500 whp for way less than 10000 hell you will have money left over for wheels and xmas presents lol.Oh turbo timer is a waste of money.
I'm going to tell you how to do this a good amount cheaper then ten grand.Ebay sells a complete intercooler intake and pipe kit 395 bucks my boy showed it to me and I'm sold its a3 1/2 inch.I'd go with a map EF3 this turbo would be more than enough power for you that 1600 through map performance.Fuel pump 200 max 1000cc injectors you may want bigger if your going e85 450/500 ish turbo back exaust should be less than a 1000
How big should I go on the fuel injectors?
And yeah I plan on installing most of the parts
Your parts list should something like this, don't go with ebay crap, go with quality parts.
ETS 3.5 intercooler 400-450$
ETS Intak, ETS UICP, 400$ more/less depends where you get it from.
Exhaust, with HFC or TP, - $ = depends on brand
FIC 1100 injectors with pnp adapters 450-500$
Fuel Pump 150-200$ with install kit
MAP EF3 & MAP downpipe = 2000$
Grimspeed 3 port = 90$
AFR, Boost Gauge, and gauge pod = 400-450$???
Dual Map tune 450-500$
I'm sure i'm forgetting something but that setup there will make you very nice power and should be safe depending on who tunes it. Whatever you have left at end, save few more K on top, and buy a new clutch and a built block from MAP. Once the stock one takes a crap, install the new block and the clutch get a RETUNE and you will be golden
