Tpms warning with new rims
Recently picked up a winter set of rims and tires and had them mounted over at my local American Tire shop. They put sensors in each of the tires as well. I didnt get the TPMS service required warning on my HUD until I had driven about 10 miles on the new tires and rims. Checked the pressures on all the tires and even had American Tire verify in front of me that all the sensors were reporting and even had them reset each of the sensors.
The mitsu owners manual said that you can get the TPMS warning if you dont have "genuine mitsubishi" wheels/rims. WTH, does that mean I'm going to get that warning everytime I drive until I put my summer/stock rims back on?
OEM sensors from your original wheels will work.
Any other set of sensors (Mitsu or other) will require programming of the car at the dealer to accept the new TPMS sensors -- and then reprogramming again when you switch back.
The other option is to get sensors programmed with the codes from your summer rims.
Check the vendor classifieds.
No affiliation, but these are the ones I was thinking of getting, should I opt for a second set of rims:
https://www.evolutionm.net/forums/ve...your-dash.html
The only thing that worries me is that I store my off-season tires directly in front of the car, in my current garage.
I suspect the car might get really confused if there are *two* sets of wheels in range when I start it.
(rant)
TPMS: The Fed's response to the tire issues on Ford Explorers -- by penalizing everyone for the dweebs who don't check their pressures.
So, having shelled out for precision tire gauges for each car, now we get to spend more on "bureaucrat engineering". Gah!
("Failure is not an option": it's the bureaucratic standard.)
(/rant)
(rant)
(/rant)
I use a set of TPMS I got from N.G.S. on my summer aftermarket wheels. My OEM TPMS are on my winter set of OEM Enkeis.
I'd highly recommend getting a set from him. It was quick, I had my codes read and had new sensors in a few days. No issues at all, and I don't have to go to the dealer to reprogram sensors every season
I NEED BOOST
Jun 8, 2013 01:42 PM
Shop TPMS
EvoX 'For Sale' Wheels / Tires
34
Jul 19, 2012 01:38 PM
Shop TPMS
Evo 'For Sale' Wheels / Tires
Apr 11, 2012 07:15 PM
