Compression test and leak down test nightmare!
Old Jun 28, 2015, 06:14 PM
DuBBzEvo27's Avatar
So I felt the motor was pretty sluggish and especially after I installed my drivenFab V3 I noticed more than usual smoke venting from it. So I decided to perform a compression and leak down test. These were my results.... Compression test:
Cylinder 1- 110
Cylinder 2- 125
Cylinder 3- 120
Cylinder 4- 75
I was shocked by the results... So then I went ahead with the leak down test... Leak down test:
Cylinder 1- 29%
Cylinder 2- 27%
Cylinder 3- 17%
Cylinder 4- 69%
Heard air hissing through the oil cap and through the dipstick. No air in the coolant lines or coming from throttle body or exhaust.... So what do you think of my findings? Time for motor rebuild?
Old Jun 28, 2015, 06:29 PM
Lightsaber's Avatar
Is this an Evo 8, 9, or X? Anyway, that sucks man, but I wish it turns out okay with minimum repair needed.
Old Jun 28, 2015, 06:32 PM
DuBBzEvo27's Avatar
2011 Evo X GSR
Old Jun 29, 2015, 06:03 AM
black E's Avatar
If air is coming out of the dipstick and oil cap then it's your piston/rings. No easy fix here, you'll have to pull the motor apart.
Sorry.
Old Jun 29, 2015, 06:35 AM
obake214's Avatar
Yup.. that would be the rings letting air into the crankcase. sorry to hear that. not sure how modified you are or your mileage but being 2011 maybe look to see if Mistu powertrain could help.
Old Jun 29, 2015, 07:57 AM
Ev0ikon's Avatar
What size injectors does it have and how was the car tuned?
Old Jun 29, 2015, 08:24 AM
DuBBzEvo27's Avatar
Stock block... Full AMs bolt ons meaning FMIC UICP LICP HFC ETS exhaust stock injectors stock turbo... Yeah I've read it's the piston rings time for 2.2l build then
Old Jun 29, 2015, 09:38 AM
Lightsaber's Avatar
Wait.. these bolt-ons are supposed to be very conservative for the stock block. How could this damage a ring or anything like that? Have you been running an OTS map or a protuned custom map?
Old Jun 29, 2015, 04:36 PM
DuBBzEvo27's Avatar
I bought the car from a "back to stock" seller via local tuner... Came with stock tune... When I went to tune the vehicle about a month ago it barely made 320 on dynojet
Old Jun 29, 2015, 07:57 PM
Lightsaber's Avatar
My wild guess is that the damage was from the previous owner(s?). I don't think you have done anything inappropriate to the car.
Old Jun 29, 2015, 08:59 PM
DuBBzEvo27's Avatar
I have driven the car less than 1000 miles since I got it about 4-5 months ago... Being that it's been winter and it spent time back at the tuner for some misc things... I owned a 550whp EVO 8 before getting the X I know it's not going to pull the same but damn dads minivan pulls as hard as my X lol
Old Jun 29, 2015, 10:00 PM
kaj
kaj's Avatar
Sounds like the seller blew the engine then sold. Sorry, man. Bummer.
ddlopresti
29
May 9, 2017 08:22 PM
b0yw0nder
Jun 4, 2016 06:37 PM
DvlInDskyz
Oct 8, 2012 06:16 AM
05blue8
Apr 11, 2009 06:51 PM
Quick Reply: Compression test and leak down test nightmare!
