2008 mitsubishi evo gsr
so i decided im going to keep my evo and im doing a full tune up. oil change with filter and crush washer, new spark plugs ngk, i ordered those 5 fuses i need. im at 50k miles and i dont think the transmission fluid or diff fluid has been changed should i do that? also my coilpacks should be fine correct? can you guys list anything else i should do for maintenance as i dont know what has been serviced recently so im just gonna do everything i can. thanks guys.
Packs should be fine. If one is/was bad, you'd notice right away. Your list is good. Yes, I would do the trans, transfer case and rear diff for peace of mind. I did the same to my X (list you you're thinking about). Picked it up with about 45k miles.
You 10000000% need to do the timing belt recall like yesterday. Get the master cylinder done same time. No fix timing chain = kaboom evo
Yes. Have the dealer run the vin and double check. Also... Did you mean the pulley/drive belt recall? The X uses a timing chain... not a belt. There's no recall for the chain.
ShoboatNYC
For Sale - Cars For Sale
Feb 16, 2013 06:11 PM
BlackMICA
Sep 3, 2008 06:57 PM
