clutch master cylinder
Old Feb 26, 2017, 06:45 PM
kusk8's Avatar
Originally Posted by gerikivan
i had the map cmc aftermarket and so far so good
nice , was it easy to install it ?
Old Feb 27, 2017, 05:48 AM
Dross99_si's Avatar
I did the install myself. It's kind of a pain and time consuming, but totally doable.
Read over this a few times and decide for yourself if it's something you want to attempt..
http://magnusmotorsports.com/wp-cont..._mastercyl.pdf
It doesn't matter that the install instructions are for a Magnus brand part. AMS and MAP install will be the same.
Old Feb 27, 2017, 06:12 AM
Robevo RS's Avatar
I actually bought the map one with the new oem i dont know how good it would be though
i am missing something here. Did you bought the new uograded plastic oem CMC with a MAP kit?
Old Feb 27, 2017, 06:41 AM
kusk8's Avatar
i got the Oem cmc kit from maperformance that's all
Old Feb 27, 2017, 07:12 AM
gerikivan's Avatar
it wasnt bad.. it was pretty time consuming and the hardest part for me was grinding the 2 holes because of the tight space..btw when your removing brake fluid reservoir make sure you dont loose the oring because i lost mine and i had vacuum leak for a week..you might need to bleed your brakes too
Old Feb 27, 2017, 08:01 AM
kusk8's Avatar
got it ! Will defenetly do it sometime tomorrow hopefully !thanks a lot you Guys have been a huge help
MisUnderStood
48
Oct 3, 2017 07:57 AM
flyingscot
Jan 15, 2013 09:41 PM
Rasputin
Lancer Tranny/Drivetrain Tech
31
Jul 16, 2012 07:04 PM
joyce1bro
Jul 20, 2008 02:06 PM
Untamed
Jun 11, 2008 10:34 AM
Quick Reply: clutch master cylinder
