Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to Install a Front License Plate without drilling the Bumper
Old Sep 6, 2009, 10:14 AM
  #46
ApexSilverXGSR's Avatar
Just put mine in the other day... I have to say it doesn't look ALL THAT bad, but it does almost completely take away the 'mean' factor on the front end...
I went a solid 10 months before anyone said anything about not having a front plate and it was great.
Old Oct 14, 2009, 03:21 PM
  #47
tazio's Avatar
About the issue of cable ties weakening over time, the thing to do is to get military spec tie wraps, for example ...
http://www.pegasusautoracing.com/pro...p?Product=4333
As well as the material being UV resistant, the little tab in the socket is metal not plastic, so the wrap is much less likely to get loose over time.
Still have some of the 30" tie wraps left over from my racing days. Amazing what repairs you can make with tie-wraps and "racing" tape (colored duct tape). The smart guys picked a good brand of racing tape first, then color-matched the car paint.
Old Oct 14, 2009, 06:04 PM
  #48
Frankiago's Avatar
I just took mine off 15 minutes ago. Instead of weather stripping, I used the soft side of velcro on the back of the bracket. I really like the zip-tie option instead of the side-mounted plate. I do need to find longer zip ties though... btw unless you're buying super cheap zip-ties, they're gonna be UV resistant.
Old Oct 14, 2009, 06:16 PM
  #49
cush87's Avatar
Seems like a great idea. I have been putting off doing my front plate cause I don't want the holes. I was going to use double sided tape. Maybe I will give this a try
Old Oct 18, 2009, 09:54 AM
  #50
After about a month of having my front plate zip tied to the bumper, it's a little loose but definitely nothing close to falling off.
My only real concerns at this point are the little scratches left by the zip ties on the plastic. Probably going to add a lot more weather stripping this time around.
Old Oct 18, 2009, 05:21 PM
  #51
pips's Avatar
An easier way is to just mount one the grilly mesh in front of the intercooler...
Old Oct 18, 2009, 06:51 PM
  #52
monkey_187's Avatar
I will never understand why people do this
Old Oct 18, 2009, 10:17 PM
  #53
wilevo's Avatar
licene plate
Nice job!
Old Oct 20, 2009, 12:58 PM
  #54
KGHtheII's Avatar
I have had this done w/ standard zip ties and weather stripping for over a year now.
Still holding strong.
Old Oct 24, 2009, 09:50 AM
  #55
raytrix's Avatar
Update, I have mine on for 1 year and 4 months. I never checked if it's loose nor have I replaced the tie straps. All I know it's still mounted on my front bumper and it's going no where.
Old Nov 3, 2009, 10:36 PM
  #56
jcdeng's Avatar
Will this work for our car???
http://www.youtube.com/watch?v=QkpctU_ui3Q
Old Nov 22, 2009, 02:19 PM
  #57
Methodical4u's Avatar
it's a good idea, and I thought about it, but i've used ties outside of a car before and they'll break after a while... they just start to dry out and break. I'm actually making a custom license plate using a few pieces of steel and some bolts that are already under the car... i'll post some pics when I get it finished.
Old Nov 22, 2009, 05:04 PM
  #58
rrd
rrd's Avatar
i know its not the same car/mount but it may be useful
i mounted some L shaped brackets to the back of mine and then drilled it in on the underside of the bumper
Old May 24, 2013, 01:46 PM
  #59
sergey.sokolov4's Avatar
wouldn't it be easier to get a vinyl licence plate copy, i know this website that makes one, its around $90 but its worth it
http://licenceplate.ca/
Old Jul 31, 2013, 12:27 PM
  #60
RYB@34's Avatar
I did mine in vinyl and it was only $20
Just go to your local vinyl shop and ask them
If they can do that, they just scan the plate and
Print on special reflective paper
Quick Reply: How to Install a Front License Plate without drilling the Bumper
