Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to: Oil and filter change on the EVO X
Old Dec 9, 2014, 08:42 AM
  #166
DSRxEMS's Avatar
good info thanks
Old Dec 9, 2014, 09:58 AM
  #167
Zippy452's Avatar
silly question but I'm assuming this is the same for the RA? I think i've come to the understanding that most of the evo (esp MR) how to's are mostly transferable to the RA
Old Dec 20, 2014, 03:53 PM
  #168
SentWest's Avatar
Just did this, great write up.
... made substantially easier for me due to the oil pan/filter cover being MIA.
Old May 28, 2015, 03:29 AM
  #169
nickyd's Avatar
Originally Posted by itznoraa
i would warm up the oil before you checked the dip stick.
My X takes about 4 and 3/4 quarts. 5 quarts seems to be too much.
You are correct. That's about 4.5 litres. Using a full 5 litres container is too much (as I found out--the hard way!).
Old Sep 9, 2015, 03:49 AM
  #170
strato614's Avatar
Great write-up, thanks. Changing the oil looks so much easier than on my A4. The A4 had this pesky filter housing with the filter element inside. Even though there was a drain port, I still managed to make a mess. But the ridiculous part was the motor mount sensor located directly below the filter housing! You have to unplug the motor mount sensor to make it easier to remove the housing....
There was this saying in the Audi world, "throw a German engineer down a hole with a ladder and he'll build a shovel and tunnel his way out."
Old Nov 29, 2015, 09:13 PM
  #171
Chris_tA_4's Avatar
Great write up
Old Mar 30, 2017, 10:29 AM
  #172
xiLLtegRax's Avatar
thanks for the write up
Old Jul 11, 2017, 09:24 PM
  #173
NoNonsensePC's Avatar
I never new what the lowest hole on the dip stick meant. Thanks for the write-up!
Old Jul 13, 2017, 05:17 AM
  #174
nickyd's Avatar
Neither did I know this. I've just re-read the post, also.
Three quarts (US) = 2.84 litres approx. That's over half the oil in the sump. Better not to go that low!
Old Sep 9, 2017, 03:59 PM
  #175
Kay
Kay's Avatar
NEED HELP!!! Oil dipstick problems
I drive a 2004 oz rally lancer and I changed my oil four days ago. I checked my oil the dipstick shows oil only on the tip, I checked for leaks no leaks at all, I filled the oil to 4 and 1/2(I add just because it's a older car). The oil light isn't on and car sounds fine I been driving it with no problems. I'm stumped can anyone please help!! Anyone come across this problem?
Old Sep 12, 2017, 01:41 PM
  #176
S13Koop's Avatar
This came in handy for me. Thanks!
Old Dec 8, 2017, 08:01 AM
  #177
zz7
zz7's Avatar
thanx
Old Mar 9, 2018, 06:11 PM
  #178
islaw's Avatar
Great writeup
For any oil change
Old May 6, 2020, 04:58 PM
  #179
jay99's Avatar
Thanks for the write up! DO any of you use any of those aftermarket drain plug quick release connectors ? If so how do you find them worth it for the 15 dollar range ? Any input would be appreciated thanks guys
Old Sep 16, 2020, 02:22 PM
  #180
Roshan John's Avatar
Great tutorial I dont trust most mechanics so thank you!
WarmMilk
942
Sep 14, 2017 08:55 AM
kaj
Aug 21, 2017 03:59 PM
bruce988jl
Dec 4, 2016 08:01 AM
lbcevo
Oct 27, 2016 12:30 AM
EVL4B11MR
Oct 26, 2016 06:05 PM
Quick Reply: How to: Oil and filter change on the EVO X
