Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to remove the top wastegate solenoid restrictor pill?
Old Jan 28, 2009, 08:58 AM
LVSBB6's Avatar
As required for running the Cobb stage 2 map, does anyone know how to remove the top wastegate soleniod restrictor pill?
Pics would be helpful, thanks!
Old Jan 28, 2009, 09:01 AM
chase123's Avatar
Easily found on the Cobb website.
http://www.accessecu.com/accessport/...Pill_Instr.pdf
LVSBB6's Avatar
Got it, thanks!
Old Jan 29, 2009, 08:26 PM
dierr's Avatar
nice. soon to be using cobb ap also.
Old Feb 9, 2009, 03:29 PM
Tunerhead's Avatar
Originally Posted by chase123
Excellent
Old May 17, 2009, 11:11 AM
h311rasor's Avatar
noob question here.... removing this pill does WHAT??? i mean can it be removed without a remap and give any kind of gain or detrimental effects????
Old May 18, 2009, 03:21 PM
sbdemon's Avatar
It allows more air either going into/or exiting the boost control solenoid, since this ultimately becomes the wastegate actuator signal I wouldn't start removing/altering them without it being required by a tune or installation of manual or electronic boost controller.
Old May 18, 2009, 04:05 PM
Hassan!'s Avatar
Thanks for the info!
Old Sep 5, 2009, 11:15 AM
grafix143's Avatar
ok here my Q , how can i put it back in
the pill which direction ?
Old Sep 6, 2009, 10:00 AM
h311rasor's Avatar
this is NOT as easy as it sounds... on my 08 X GSR i cant even get the hose off the connection to remove the pill.. i bought the cobb tuner i used it then i decided to remove the pill to remap for stage two... i tried and tried over and over pulling on the hose.. it stretches .. but will NOT come off the darn connector... i gave up and remapped to stage one where you dont need to remove the pill. hehehehe
Old Sep 8, 2009, 06:42 PM
PlayinWithFire's Avatar
use a long allen wrench... thats how i got mine out.
Old Dec 15, 2011, 07:06 PM
johnnnyjeans's Avatar
or you can get a new tube without the pill in it. if you can't get it out.
Old Dec 15, 2011, 08:10 PM
wallace989's Avatar
pliers work well to get the clamps off the end
Old Dec 16, 2011, 07:04 PM
user 629782012's Avatar
with a hot engine bay and some pliers the top tube will come off easily.. if you have to use a screwdriver "pick" it's a pointy end driver to hook the hose as you, slowly but firmly pull the hose off the barbed end. once that is done then take a small allen key wrench to put slide in to the hose while pushing the pill out.
I've done this process a couple times and it's worked for me. as for the pill direction.. i didn't make a note on which direction it should be.. but ive never had a problem either way.. a hole is a hole.. unless it's supposed to have a "venturi effect" then the direction would be important.
Optiblue
26
Feb 20, 2014 01:05 AM
sna08
55
May 6, 2013 01:04 PM
Randal
Oct 23, 2012 07:53 PM
honda-guy
Mar 23, 2011 01:52 PM
masterevo
11
Oct 9, 2004 12:08 PM
Quick Reply: How to remove the top wastegate solenoid restrictor pill?
