Fog light bulb replacement
I searched and can not find out how to replace the fog light bulbs?? Do you need to go in from the fender well? Thanks for any help.....
Thanks man!!
is it a new site policy to remove links to other forums?
does anyone have any instructions on how to swap bulbs? prob a post would be better than a link.
thanks in advance!
thanks in advance!
really? it's in the owner's manual?
i'm surprised that it is since usually manufacturers don't want the owners to fiddle with anything that can be done by the dealership and in turn make money for them.
i will check it out. thanks for the info.
pretty sure they won't tell you to bring it to the dealership for a burnt light bulb. just turn the wheel away from the side you want to change, pop off 3 plastic rivets and a 10mm screw that holds the liner to the bumper. then you have access to the foglight
nice, i just got and installed 3000k yellow HID fogs, they look amazing. there's perfect places under the headlights just to the side for the ballasts. took about an hour start to finish to take off the front end, install the ballasts and hids, breaking them in for 10 mins, and putting the front end back on.
nice, i just got and installed 3000k yellow hid fogs, they look amazing. There's perfect places under the headlights just to the side for the ballasts. Took about an hour start to finish to take off the front end, install the ballasts and hids, breaking them in for 10 mins, and putting the front end back on.
