Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HOW TO: Make a distribution block for Gauge Installs/Radar Detectors/Anything else.
Old Feb 17, 2012, 08:02 AM
  #106
Evolution Z's Avatar
Originally Posted by Clipse3GT
It's just a ground the other is just power.
are the two blocks connected to eachother?
Old Feb 17, 2012, 08:19 AM
  #107
rayman0690's Avatar
This is a fantastic idea. I really like this. I might try something similar on my VIII
Old Feb 20, 2012, 12:50 AM
  #108
dare599z's Avatar
Awesome setup! Thanks for the diagrams! Going to do this next weekend.
Old Feb 25, 2012, 01:56 PM
  #109
OP, will you please make a simple, yet thorough, schematic?
Old Mar 3, 2012, 08:36 AM
  #110
Steven_Trujillo's Avatar
So I'm giving this a try today and so far I have everything together the Distribution Block for Power but every time I plug in the fuses they blow out! So am I missing something or do I have to hook everything I'm connecting to it first then plug them in? Help please
Old Mar 7, 2012, 10:26 AM
  #111
bobby.is.rad's Avatar
You'd have to run two wires to every device with a ground block instead of just running a short wire from the device directly to a ground close to it. I'm sure there's a good reason for doing this, but I can't figure it out. Can someone explain?
Old Mar 12, 2012, 06:54 AM
  #112
Just used this how-to to install WB, boost gauge, radar detector, and iPhone charger this weekend. Thanks for a great write-up! I definitely felt a lot better about installing that stuff knowing that I wasn't hacking up any of my factory wires. I had a DSM with electrical problems, and it was a nightmare, so I'll gladly take any precautions to avoid that.
Old Apr 1, 2012, 08:08 PM
  #113
Get Rad's Avatar
Anyone ever have any issues with drawing to much power out of fuse source? I would be worried that I would be running to many items at once from the one fuse. Also would this be considered like wiring gauges in parallel?
Old Aug 2, 2012, 03:09 PM
  #114
Spazo's Avatar
Anyone connect a micro USB device to the block? I'd be interested to see / read how you did it.
Old Apr 1, 2015, 09:01 PM
  #115
Hunndy's Avatar
Got a question, why do you have 3 power lines (fuse taps) for 2 gauges? I must be missing the boat, or not reading carefully. Is one to the hazards fuse for dimming?
Finally, could you only have 1 fuse tap going to the cig. lighter fuse for many gauges?
Or do you need one tap for each gauge?
Old Apr 22, 2015, 05:55 PM
  #116
uprise's Avatar
Well it leaves room for expansion and it is best to run the wideband on it's own. Separating it keeps the gauge reading accurately and while data logging. But again it all depends on your set up and power requirements for the gauges you choose to use. I have seen some require 12 volts and others only need 5 volts. So do what is best with what you have.
Old Sep 12, 2016, 01:13 PM
  #117
boostedmoose003's Avatar
Bringing this one back up from the dead. Does anyone know where to find the terminal bridge for the barrier strip? All the Radioshacks near me do not have them and are not available on their website.
Old Dec 2, 2016, 07:22 PM
  #118
Matt326's Avatar
This is one of the most helpful how-tos I've come across so far. I was looking for a way to power my gauges without cutting into the cars harness and keep everything clean looking under the dash. Thanks to the OP for the idea.
Old Dec 27, 2016, 06:59 PM
  #119
lkailburn's Avatar
sub'd! nice job
Clipse3GT
44
Jan 29, 2022 09:54 PM
Clipse3GT
Jun 24, 2018 09:47 PM
Clipse3GT
24
Jul 28, 2017 01:44 PM
Lightsaber
Jun 7, 2017 03:58 PM
mrwickd123
11
Nov 2, 2016 10:19 PM
Quick Reply: HOW TO: Make a distribution block for Gauge Installs/Radar Detectors/Anything else.
