Remove Factory Hid bulb?
Does anyone know how to remove the factory HID bulb from 2010 Evo x projection headlights? Do you have to remove the whole light assembly?
Thanks.
Thanks.
Saw this is kind of an old post but I recently changed my hid bulbs. me and my friend ended up just removing the whole headlights and changed the bulbs. so much easier to see what you are doing. for any future ppl who plan to do it
Its really easy to get the headlight out, it requires the removal of the front bumper but is like a 5 min process. Search the forums for details, I've seen a write up and suggest this way, just so you don't happen to mess anything up, better safe than sorry
The bulbs are: D2S
read my posts. #92 onwards:
https://www.evolutionm.net/forums/ev...ml#post8859587
Just did mine earlier today, I didn't have to remove my bumper/headlights. Just removed the coolant reservoir on the pass side and the small fuse bracket on the driver side to free up some room to get my hands in there.
After removing the round plastic caps you simply twist off the HID connector. Then unhook the 2 wire clips that hold the bulbs in place (although this can be infuriating to someone who doesn't know how D2S clips work). Since you can't get an angle to see them you have to do this by touch, and then pull the bulb out. Then do that in reverse (when installing the new bulb, remember that the "notch" on the plastic part of the bulb should be oriented up). Took me about 10 mins total.
My new 8000K's look fantastic. I'd recommend trying this first before a full blown bumper removal. Wasn't too hard, but I've replaced many D2S bulbs before.
same struggle here. managed to remove the round cap but got no clue how to dislodge the hid bulb. my 8000k bulb sitting for months now. haven't tried a second attempt, maybe this weekend
