need help with bc coilovers
hi i recently installed bc coilovers on my evo x , i got it done at a performance shop now the rear makes a cluncking sound every time i go over bumps, little ones, over the big bumps its fine no problem at all, the shop cannot figure out what it is, they installed my original suspension and the car continue to make that noise,so now its not the coilovers, i have no idea what it could be, and the shop is scratching their heads as well, it sounds like metal on metal like something is loose, any help would be apperiaciated thankyou
It's pretty normal with coilovers that have pillowball upper mounts. I had a rear clunking on all the 6 coilover sets I've owned on various cars - everything from megans to ohlins. Rubber upper mounts = no clunking.
it came to my attention that they only changed one side of the car to original and then tested it so the noise was still there, so i guessing it was the coilovers, i contacted bc and they make a rubber option so i will be getting a set of these hopefull this fixes the problem
jkim2001
Jan 12, 2007 11:50 AM
