Steering wheel shakes at high speeds after re-balance
I bought some new Rota Grids 18x.9.5 and had a set of Hankook EVO V12 tires mounted and balanced. At first I would get very bad shaking going 75+, so I had the front wheels re-balanced at sears and got a 4 wheel alignment (since the stock alignment eats tires), but that made no difference.
So I went back and had them re-balance the front wheels again, and then balanced the rear wheels at the same time which stopped maybe 80% of the vibrations. Currently, going above 75 results in visible steering wheel vibrations, rear view mirror slightly shaking, and can be seen if I place like a dunkin donuts coffee cup in the cup holder.
Going under 75 the shaking stops. I am using McGuard lugnuts, with hubcentric rings on all 4 wheels and the Rota centercaps...Anyone got any ideas?
tl;dr:
Bought New Rota Grids with hubcentric rings and McGuard splinedrive lugnuts
Steering wheel, rear view mirror and cup holder shake when going 75+
4 wheel alignment, all wheels re-balanced 3x and car still vibrates
tl;dr:
Try a different garage. For tire M/B and alignments I only use shops with Hunter Tire and alignment machines.
I have the Hankook V12's which work great in the wet and dry especially for the $$
Try to get a road force balance (FIRESTONE shops have them around here). That will determine if it is the rim or the tire. Some tires are just out of round and need replaced. I recently had the same problem with some BRIDGESTONE tires on my SUV. I had 2 tires that were really out of spec replaced and that solved the vibration issues.
If you search Hunter roadforce balance 9700 you will find thir website andthey post locations of who has their machines. Try this link http://www.gsp9700.com/pub/search/findgsp9700.cfm
g7igo7
12
May 11, 2016 08:33 AM
