Mitsubishi Lancer Evolution Rear Strut Brace
Has anyone bought this or had it installed? Is it worth the money to have it or are there better alternative to the OEM one that dealers are offering. your thoughts please. thanks.
was looking into getting it for a better ride, just not convinced it's worth it just yet...maybe later down the line. This is for a 2011 evo MR that is barely 300miles.
Should i wait and enjoy the stock ride for a bit before i pose these kind of questions?
I bought a cusco rear strut bar and it did make a slight change in turn entry in reducing understeer. The sway bar will do more, but if it's overpowering your springs and strut droop causing tripoding it's not worth purchasing. I'd recommend going with stiffer springs all around first.
Front: MacPherson type strut(inverted strut) with forged aluminum control arms MacPherson type strut(inverted strut) with forged aluminum control arms
[Eibach springs and Bilstein shock absorbers]
Front Stabilizer Bar Diameter (mm): 25
Rear: Multi-link type suspension with forged aluminum control arms, Multi-link type suspension with forged aluminum control arms
Rear Stabilizer Bar Diameter (mm): 23
i guess the stabilizer bar is different from a sway bar? please advise, but i honestly thought they were the same thing based on this definition...
Stabilizer bars are part of a car's suspension system. They are sometimes also called anti-sway bars or anti-roll bars. Their purpose in life is to try to keep the car's body from "rolling" in a sharp turn. from "how stuff works, website.
i use my evo, for DD and will most likely not see any track time or canyons ( i have a motorcycle for that) but i still would like a great ride. maybe for daily driving, the stock stuff listed above is fine, no? Should i be looking into adding a front brace, sway bars, strut bars, etc...if i only commute? or am i wasting my time and $.
sorry, this is a nOOb question, but isn't the sway bar stock on 2011 evo x? i double checked the specifications and it said this:
thanks for clearing that up. for DD yes, i will stay stock and save the money up for the navi that i didn't get.
vhalin
34
Jun 3, 2012 07:07 PM
stlgrym3
36
Oct 18, 2010 09:17 PM
