What size wheel spacers can I run on stock EVO X GSR wheels
I am Painting my stock evo x gsr wheels and I was wondering if I can run a spacer to get them to sit a little better. I have tein s lowering springs and there rest of the suspenion is stock.
Thanks
Caleb
Thanks
Caleb
If you get extended studs put on you can run all sorts of different widths.
I have a set of Sparco spacers and extended studs on the car. I am also running the stock wheels and stock lugs. I'm running 16mm spacers with stock wheels.
Cut the ends/caps off the lugs and you have open ended lugs with a flat bottom to use with your stock wheels.
