Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
CV boot leaking/front axle replacement
Old Jan 12, 2017, 10:54 AM
97laxlude's Avatar
Hey guys,
So I went to get my clutch replaced and it looks like both outer CV boots up front were leaking bad. I didn't notice it last oil change so no telling how long it's been like this. Normally I'd just get a CV boot kit but I'd rather not risk it and just replaced the front left and right axle.
Any recommendation or experience on where to source a front left and front right axle? The dealership wants near $800...a piece.
Old Jan 26, 2017, 08:26 AM
popdakebin's Avatar
I have the same exact question. Mine has been leaking. Not sure if that's what's contributing the noise I am getting.
Old Jan 26, 2017, 12:49 PM
six40's Avatar
Most times it leaks due to the factory clamps being weak and losing their clamping force on the boot against the shaft, if you will. If they're not clicking and making noises when turning, you more than likely just need the clamps assuming the boot isn't torn.
If there is damage (usually clicking noise when turning sharp at low speeds) , it might be easier to get them rebuilt by somebody that specializes in such thing over buying them brand new from Satan.
Ermo_x (Apr 22, 2018)
Old Jan 26, 2017, 05:09 PM
AJ18's Avatar
ill be replacing my passenger axle soon. i noticed that both the the outer and inner boots were torn. i have no idea how long thats been like that since i bought the car used. i bought my axle off of mitsubishipartswarehouse.com they are selling it for $650ish dollars. i just need to find a shop to replace it. i would normally do it myself but there is soon on the ground i dont have a garage available to me.
Old Feb 15, 2017, 01:35 PM
lui_ming_92's Avatar
If the axle isn't clunking just buy a CV joint kit inner or outter and squeeze that googy stuff in the rubber housing and pinch it with something and you're done. I done it my self and i have been driving it for 25K miles with no issue.
Old Feb 15, 2017, 04:03 PM
4b11slayer's Avatar
Find a reman axle place.
Should be like $120 each with core.
Old Feb 23, 2017, 08:03 PM
popdakebin's Avatar
Is the drive axle supposed to be hard to move? When I grab the axle, I can move it in and out a little bit and can hear some clunking noise. Am I supposed to be able to do this and is the noise normal? The car is jacked up but everything still installed.
Old Feb 24, 2017, 09:25 AM
4b11slayer's Avatar
the axle moves in and out in the housing it isn't a fixed design.
They have a locking ring inside the differential to prvent them from just sliding off.
Use a pry par to separate from trans and transfercase.
Use a fast motion on the pry bar vs a constant pressure sometimes if you don't "snap it" the clip wont let go.
Old Feb 24, 2017, 10:22 AM
popdakebin's Avatar
Thanks! I guess that means I can buy the replacement boots and hope that fixes it.
Old Feb 28, 2017, 07:11 AM
jakgal04's Avatar
Both of my rears are leaking. I was thinking about getting the lube+reseal kit, but I've been pushing it off for almost a year now. The good news is you can get replacements on eBay for pretty cheap.
Johnr352
11
Oct 15, 2014 07:59 AM
ProPilot04
May 17, 2013 10:55 AM
MitsuJoe
10
Oct 2, 2011 08:26 PM
heel_touge
Feb 15, 2011 11:11 AM
RAKenzo
Aug 30, 2005 12:58 PM
Quick Reply: CV boot leaking/front axle replacement
