The official EVOM vocabulary and reference guide
When people talk about cars and car related items, they tend to use a lot of acronyms and special term which can make things very hard to understand. This handy vocabulary is created to help you understand these terms and make it easier on you to read the forums. Notice that the list is organized in alphabetical order for quick reference. Also, as you can see, some of the terms are actually links to where you can find more info on the specific term. If you find that there is a term missing from the list, please PM me with the term missing and I will update the list.
1-10
1G - First Generation
2G - Second Generation
A
ACD-ActiveCenter Differential
AWD- All Wheel Drive
A/C - Air Conditioning
A/F - Air/Fuel Ratio (can also be referred to as AFR)
A/T - Automatic Transmission
ATDC - After Top Dead CenterAFAIK - As Far As I Know
AS - Apex Silver
B
BHP- Brake Horse Power (mostly used in England)
BAR 1 BAR - 14.508 psi
BTDC- Before Top Dead Center
BOV – Blow Off ValveBUMP- Bumping A Thread Up to The Top
BBY - Blue By You
C
CT9A- The Chassis Code of the EVO 7-9
CP9A- The Chassis Code of the EVO 3-6
CPS - Crank Position Sensor
CAS - Cam
Angle Sensor
CV - Constant Velocity Joint
CAI - Cold Air IntakeD
DOHC - Double OverHead Camshaft
DV - Diverter Valve
DSM - Diamond Star Motors
DW - Diamond White
E
EVO- The Legendry Lancer Evolution J
EVO FQ300, FQ400 Etc. – Limited Edition made by Ralliart Available i Europe
ECU FLASH – Modification to the OEM ECU to Increase Performance
ECU- Engine Control Unit
EFI- Electronic Fuel Injection
EDM – European Domestic Market
EBD - Electronic Brake Distribution
EGR - Exhaust Gas Recirculation
EGT - Exhuast Gas TemperatureEBC - Electronic Boost Controller
EB - Electric Blue
F
FWD- Front Wheel Drive
FI - Fuel Injection
Ft.Lb. - Foot Pound
FPR - Fuel Pressure RegulatorFYI- For Your Information
FMIC - Front Mount IntercoolerFR - Front-engine, Rear Wheel Drive
FF - Front-engine, Front Wheel Drive
G
GAL - Gallon
GND - Ground
GVW- Gross Vehicle Weight
GG - Graphite GreyH
HP - Horse Power
HID - High-Intensity Discharge
HVAC - heating ventilation and air conditioning system
I
I/C – Inter Cooler
in. lbs. Inch pounds (12 in. lbs. in a foot pound)
in. Hg Inches of Mercury (vacuum)
Injector latency - the amount of time for the injector to open
IIRC- If I Remember Correctly
IMHO – In My Humble OpinionJ
JDM- Japanese Domestic Market
K
L
LHD - Left Hand Drive
LSD – Limited Slip Differential
LH - Left Hand relating to parts LH is always the driver's side
LICP - Lower Intercooler Pipe
LOL- Laughing Out Loud
LY - Lightning Yellow
LB - Labrador Black
M
MMNA- Mitsubishi Motors of North America
Mitsu – Mitsubishi's Nick Name
MAF - Mass Air Flow
MAP - Manifold Absolute Pressure (also know as Speed Density)
MAT - Manifold Air Temperature
MPG - Miles per Gallon
MPH - Miles per Hour
MSRP – Manufacturer Suggested Retail Price
MBC - Manual Boost Controller
MIVEC - Mitsubishi Innovative Valve timing Electronic Control
MB - Mystic Blue
MS - Munich Silver
MR - Mid-engine, Rear Wheel Drive (also a special edition evo model)
N
NEWBIE - New Person on the Board (also refered to as Noob)
O
OBD- On Board Diagnostics
OTD- Out The Door price (the price you paid after tax and fees)
OEM - Original Equipment Manufacturer
P
PSI - Pounds per Square Inch (usually used for measuring boost pressure and tire pressure)
PWR - power to weight ratio
PR - Phoenix Red
Q
R
RALLIART – Mitsubishi High Performance Division
RWD- Rear Wheel Drive
RHD – Right Hand Drive
RON - Rated Octane Number
RPM - Revolutions per Minute
RH - Right Hand relating to parts RH is always the passenger side
RR - Rally Red
RR - Rio Red
S
SAYC- Super Active Yaw Control (not available on USDM cars)
SUBARU/ SOOBY – The EVO Arch Nemesis (namely the STI)
SRS - Supplemental Restraint System (air bag)
SSL – Another Trim Level of the US Evo ( Sound, Sun and Leather)
SOHC – Single OverHead Camshaft
SEARCH - using the search function of the site (sometimes refered to as search n00b)
S-AFC - Super Air Flow Converter
T
Trim Levels - GSR, RS, GT-A, MR (RS= light weight stripped, GSR= Loaded, GT-A= Auto Evo, MR= Mitsubishi Racing Limited Edition)
TACH - Tachometer
TB - Throttle Body
TBE- Turbo Back Exhaust
TSB - Technical Service Bulletin
TO - Terrill Owens or Throw-Out Bearing J
TDC - Top Dead Center
TPS - Throttle Position Sensor
TC - Transfer Case
TTIWWOP – This Thread is Worthless Without Pictures
TTT- TO THE TOP
TT - Turbo Timer (also twin turbo)
TB - Tarmac Black
TG - Thunder Grey
U
UICP - Upper Intercooler Pipe
USDM- US Domestic Market
V
W
WOT- Wide Open Throttle
WHP- Wheel Horse Power (actual power at the wheels, can be fwd, rwd or awd)
WG - Wastegate
WW - Wicked White / Weightless White
X
Y
YMMV – Your Mileage May Vary
Z
LB - Labrador Black
M
MAF - Mass Air Flow
MB - Mystic Blue
MS - Munich Silver
N
O
P
PR - Phoenix Red
Q
R
RR - Rally Red
RR - Rio Red
S
T
TACH - Tachometer
TB - Throttle Body
TC - Transfer Case
TTT- TO THE TOP
TB - Tarmac Black
TG - Thunder Grey
U
V
W
WG - Wastegate
X
Y
Z
TopSpeedAutoSport
Evo 'For Sale' Wheels / Tires
94
Aug 10, 2011 12:08 PM
