evo 8MR/9 ACD vs. STI DCCD
for the advanced users that owned or owns both EVO and STI, can you guys chime in?
i swapped in a JDM spec-c 6mt into my WRX and i use an aftermarket DCCD unit to control the center diff. it's 100% manual with a few auto features. nothing advanced as the OEM Auto feature tho. i'm really interested in the EVO9MR and i wanted to know as much as i can before i get my foot into one.
so how would you guys compare the evo's ACD to the STI's DCCD? all i know is that the evo has 3 settings but can you manually control it like the sti's DCCD?
*for those that were wondering if the STI's rear can whip out...
http://www.youtube.com/watch?v=T4nFIyP-WOw
i'll be owning both cars hopefully. i won't get rid of my subie. i jsut want to know what owners have to say.
ie. using snow ACD on gravel or using gravel ACD on tarmac. any advatages or disadvantages etc.?
there's a sticky here somewhere explaining exactly how ACD works.
edit: here u go. (better to give u this than to explain it in my own words lol)
https://www.evolutionm.net/forums/sh...d.php?t=175195
the acd on the evo isn't 'controllable' like the one in the subie, but you can get it flashed or even get it to have several modes more than the original 3.
I would say that it's not as noticable as in the subie. I mean, if I lock it on my subie, it starts popping at full steering lock. As far as I know, the evo's system actually does quite a lot of sensing to work out what to do so it's virtually always in 'auto' mode - what mode you put is it just change a few constants used in the calculation of the 'auto' controller. The Subie system mainly has one 'auto' more and it works from there regardless of the surface (but it still takes info from the various sensors).
The main difference with regards to sliding and so on is really to do with the more rear-biased torque on the pre '05 sti's (35:65) while the '06 are more like 45:55 plus the wheel base on the evo is longer. Some people also do rwd conversions on them.
You might know already, but here's a good link to how the dccd work.
http://wallace.as.arizona.edu/~cgrop.../DCCD_FAQ.html
I've got both an STi and a IX MR. The DCCD feature is pretty cool if you take the time to learn which it sounds like you have. Then you also know that it is the only way to really get the STi to get the tail out. Mine is an understeering pig when it's set on the auto mode. When I set the control to the rear I can get the car to oversteer and feel more like a good rear wheel drive car.
The IX set on tarmac mode will oversteer without any problem. I've tried to on dry pavement in the gravel mode too with the same effect but IMO your best bet is to set it for the appropriate setting and just drive. The car becomes very predictable and the rear will slide out very easy. But it is controllable and predictable with the throttle. I used to own an E30 M3 which is the best handling car I've ever owned. The IX handles and behaves very similar to the M3. The steering is just as sharp and precise as the M and the car will oversteer just as smooth and predictable as the little M. I just wish the Evo could get into the sub-3000 lb weight class like the M3.
thanks for the response guys. i'll read more about ACD in the sticky.
Max-Q - you make me want to rush and get an EVO today! but i have to financially plan, in other words save up for a nice downpayment so i won't be butt hurt with high monthly payments.
before i traded in my 05 STi i used to be able to get the rear end to slide out in auto mode with no problems at all....never really experienced understeer in the sti...and i haven't had the MR long enough to tell anything about the ACD
The Evo is definitely more "fluid" in its maneuvers but grab the STi by the neck, give it a good wringing, and it will most certainly get up and dance.
Dowve
Mar 12, 2014 06:40 PM
ru4real
May 31, 2005 06:47 PM
Gendo Ikari
Jun 24, 2004 08:47 PM
