Need some real help, Can i put a 20G compressor housing and turbin on my Evo 8 16g?
Just as the title says, Can i put a 20G compressor housing and turbin on my Evo 8 16g? i would take it to a Turbo shop to get it done professionally of course.
Like the one in the pic :
Uploaded with ImageShack.us
Specs:
Item Name
Mitsubishi TD06 Turbo Compressor Housing ( Fit 20G Comp. Wheel)
+ TD06-20G Compressor Wheel
Item No.
1 x 0500-820-024 ( Wheel)
1 x 0800-821-020 (Housing)
Cover Dimension
- Inlet OD : 56mm / 2.21 inch
- Outlet OD : 50.4 mm / 2 inch
Wheel Dimension
- Inducer: 52.5mm
- Exducer: 68 mm
- Height: 31.5 mm
- No. of Blades : 6/6
- Bottom Type: Super Back
Application
- Replace TD05 / TD06 Turbo
And with the 11.5 turbin housing
Now i might add this as well if the evo 8 turbo cant put out lol
Pic:
Product Info
Item Name
MITSUBISHI EVO7 GT-A TD05HR / 9cm Turbine Housing Smallest
Item No.
1000-825-416
Specification
- The smallest / Fastest spool turbine housing from EVO 4~9
Application
- EVO 4~9 stock Turbo
- Make your stock EVO 4~9 spool faster.
A/R
- 9cm
Quantity
- 1 x Turbine Housing
- 2 x Gasket
Specs:
Item Name
Item No.
Cover Dimension
Wheel Dimension
- Inducer: 52.5mm
- Exducer: 68 mm
- Height: 31.5 mm
Application
Pic:
Product Info
Item Name
Item No.
1000-825-416
Specification
Application
A/R
- 9cm
Quantity
- 2 x Gasket
Please read young grasshoppa!
http://store.forcedperformance.net/m...=Turbo-Upgrade
do yourself a favor and buy a Evo 9 turbo. you'll make more power then an any "Evo 8 20g" An Evo 9 turbo can be had for under $500.
I would like someone who can provide evidence that an 8 turbo with a 20g wheel and 10.5 hotside would flow less than a 9 turbo with the same hotside and smaller wheel maybe I'm way off base and semi retarted
* Just did a update, looking at getting the 11.5 Turbine Housing as well.....But i might just end up buying a evo 9 20g with the install kit, all up to how good of a deal i can find
BIGJEFF
Apr 24, 2016 07:57 PM
bluepeartype-s
Dec 13, 2015 12:20 PM
Headgames Motorworks
Jun 2, 2014 04:20 AM
Kc2Buk
40
Nov 19, 2007 02:41 PM
