paint stock brembos and keep sticker?
Old Jan 27, 2011, 12:37 PM
nobodyphil's Avatar
i want to paint my stock red brembos cuz they are fading and are turning pink, how do i keep the white brembo sticker and not paint over that?
nobodyphil is offline
Old Jan 27, 2011, 12:41 PM
MR BURTON69's Avatar
From what i have heard is you gotta sand them down and paint or powder coat them. Then order a brembo sticker for them and put it back on. Then if you want you can clear over the sticker too.
MR BURTON69 is offline
bluebanana23's Avatar
Those things are like 6 bucks on eBay.
bluebanana23 is offline
Old Jan 27, 2011, 12:49 PM
05blue8's Avatar
If it's just the clear coat peeling off which is almost always is then you can just use brake parts cleaner on the caliper, let it soak on there, the clear coat will bubble up, spray it down with high pressure water to wash the clear coat off (you may have to use a tiny flat head screw driver on some parts of the crevices to get the old clear coat off) but the brake parts cleaner will bubble up most of it. Then I went with 1200 grit wet sand paper and wet sand very very gently and even more gently over the stickers, then respray with high temp clear coat and they look good as new. Let me see if I can find pictures....
05blue8 is offline
Old Jan 27, 2011, 12:53 PM
nobodyphil's Avatar
ok thanks, i havent cleaned them yet, ill try that, they just are fading pretty bad and look pink
Old Jan 27, 2011, 12:56 PM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
Closed.
Search, read the thread on how-to do this. Search. All threads you have started are well covered. Creating more threads without searching makes clutter.
Smike is offline
Pure Playaer
Mar 30, 2022 07:42 AM
1-12-9
Mar 2, 2016 07:10 AM
evole97
11
Aug 28, 2014 09:53 PM
evoboy8990
21
Jan 24, 2007 10:39 AM
Quick Reply: paint stock brembos and keep sticker?
