Help, MAF Shuts car off.
Here's the situation, when I plug the MAF in on the intake it immediately shuts the car off... When I remove the maf from the intake and plug it in the car will run without shutting off, once I start moving the MAF back towards the intake it will start to die out...
I cleared all the codes and plugged the maf in with it on the intake, started it a couple times and this is what came up:
P0102- Mass or Volume Air Flow Circuit Low Input.
P0113- Intake Air Temp Circuit High Input.
P2228- Barometric Pressure Circuit Low Input.
Car has a brand new MAF(399)... Previous owner tried 3 different MAF's... Has a new IAC and top end... The car had the same problem before the new top end was done.
2005 Evo8
I need some suggestions, any help will be appreciated.
2005 Evo8
UnholyMaggot
Jul 11, 2016 09:46 PM
SpeedLimit55
28
Dec 23, 2015 02:27 PM
