Redline Fluids for evo 9
I am trying to see if you guys can tell me which reline fluids go where and which get mixed. I got them from the guy I bought the evo from. I tried searching redline cocktail but it seems as if I have a lot more fluids than what everyone is listing.
I have:
(1qt) of MTL
(2qt) of 75w90 gear oil
(2qt) of MT90
(1qt) of Mitsubishi Diamond ATF SP 3 Automatic Transmission fluid
if you guys could help me out that would be great.
also I am getting my new clutch put in my evo next week and wondering if any of these fluids get changed at that time.
Thank you,
Cody
I have:
(1qt) of MTL
(2qt) of MT90
Thank you,
Cody
Diamond att is for the acd. Search for how to thread on how to bleed the acd.
Mt90/mtl are a cocktail for transmission.
75/90 is for rear diff.
Only thing your missing is mitsubishi diagueen for the tcase. You'll need this as you have to drain the tcase to do a clutch. You can get a gallon from a stealership for $60-$80. Lasts along time though as the tcase requires about 3/4qt. Diagueen is the only fluid that should be in the tcase, I wouldn't suggest substituting for anything else.
I have:
(1qt) of MTL (Mix this with the MT90 to go into the trans. Trans takes 3 qts)
(2qt) of 75w90 gear oil (For the transfercase, that's personally what I use.)
(2qt) of MT90 (Transmission oil.)
(1qt) of Mitsubishi Diamond ATF SP 3 Automatic Transmission fluid (ACD fluid. Needed if ACD line is ever removed from transfercase.)
Thank you,
Cody
I have:
Thank you,
Cody
thank you!
kevster907
Oct 5, 2014 08:41 PM
SOUNDWAVE333
Nov 10, 2013 06:24 AM
Jeffs2006EVOIX
33
Aug 19, 2013 07:47 PM
