"Oil Change frequency"
A few weeks ago I posted a concern regarding the inconsistencies between mitsu dealers and the owners manual re: oil change frequency and type of oil to use. I called mitsubishi motors and spoke to a rep who basically quoted what's in the manual.
For the record. Change oil every 3K and use synthetic. May affect the warranty if otherwise.
I appreciate all the feedback that I got. Thanks
gene
ruston, la
gene
ruston, la
Just out of curiosity, was there a reason why you didn't trust what was in the owners manual to the point where you went out of your way to contact multiple dealerships and eventually Mitsubishi?
Yes, very much so. Our nearest mitsu dealership is 75 miles away and really has not had an evo on their lot in about 5 years or so. I purchased my 14 MR in dallas, Tx which is 250 miles away and is the largest evo dealer in >/< 500 mile radius (don herring mitsubishi). I read the manual first, called dallas dealership to simply ask if I can use a local (certified) outfit here in town assuring them that I would use synthetic. First response by that service mgr is "does not need synthetic" (this was the first doubt that spurred my curiosity). Next, I called the mitsu delaership here in shreveport, la. They said synthetic, I said, good, I'll take it there. Took it there, had it changed and sticker on window showed that next oil change schedule was 5K miles! Again another deviation from the book, so I decided to post it here and got different opinions as well. This is what brought me to call Mitsu motors.
The short answer is that a 3000 mile change interval with a 100% synthetic 10W-30 oil and an OEM filter is absolutely safe for your car.
The long answer is you're going to get different opinions everywhere about motor oil brand, weight, and change intervals.
If you run a high quality synthetic like Amsoil (dealer probably put Mobile 1 in your car - most people around here aren't a huge fan) for example, a 3000 or 5000 interval isn't going to make much of a difference. Especially when your car is new and stock (I'm assuming you want to keep your warranty for awhile). Personally I wouldn't go over 3000 miles using an OEM filter, and my emotional argument regarding all this would be to never go longer than 5k miles for an oil change regardless of what you're using (see link below).
Now all that ^, is my opinion.
All of that said, a 3000 mile change interval is kind of ridiculous with a full synthetic oil. The point of a synthetic oil is that is doesn't break down as quickly as conventional oil. The reason for that is because of how synthetic oil is engineered with large identical molecules that will retain similar flow behavior at high and low temperatures. Basically they have a better viscosity index than conventional oil so they require a smaller amount of "viscosity index improvers," which essentially are a polymer additive that thickens the oil as the temperature increases. Polymer additives undergo a lot of thermal and oxidative degradation, and because of the nature of synthetic oils less of these "improvers" are required, so the oil doesn't break down as quickly. In my mind when using a synthetic oil your biggest limiting factor on change interval is what filter you're using.
Other people will argue other things like to only use high ZDDP oils and do more frequent oil changes (this is what I'd recommend for someone well above stock hp levels). Others will argue to run something like Rotella T3 15-40 (which has detergents, so it can be used for a longer interval) regardless of hp level. But I won't dive into that too much because it's not really what you're asking.
See this thread regarding filter choice:
https://www.evolutionm.net/forums/ev...63t-4b11t.html
it's funny you said that "karl". I had an 07 bmw33i prior to my evo. oil change frequency is dictated by driving habits. my avg oil change fell between 15K up to 20K miles! This was so hard to fathom since i would push my bimmer quite hard. Again, I called bmwusa re: this. They informed me that the key was not only in their synthetic oils but more so in their "filters" like you suggested. I personally kinda enjoyed the less frequent oil changes. Though bmw has free maintenance up to 50k miles, it still didnt take as much of my time to get the car serviced (40 miles away).
gene
ruston, la
gene
ruston, la
You don't have to change at 3k, it depends how you drive the car, type of oil, type of fuel ect...
They're concerned with frivolous lawsuits from idiots who can't protect themselves from their own stupidity... not saying that that applies to anyone here. But it's part of their procedure, just like flight attendants having to explain to everyone how to put on a seatbelt.
mRVRsport
Outlander Sport
67
May 5, 2017 04:56 AM
EvoStormTrooper
Jun 9, 2014 10:30 PM
Street gear
14
Aug 11, 2011 08:55 AM
