RallySport Direct's Ultimate Engine/Drivetrain Thread!
This is RallySport Direct's Ultimate Engine/Drivetrain Thread! Here you will find all the guts to put your motor back together. For pricing, please click on the product description!
CLICK HERE FOR CAMSHAFTS
CLICK HERE FOR BOLTS AND FASTENERS
CLICK HERE FOR HEAD GASKETS
CLICK HERE FOR ROD BEARINGS
CLICK HERE FOR MAIN BEARINGS
CLICK HERE FOR VALVE GUIDES AND RETAINERS
CLICK HERE FOR VALVE SPRINGS
CLICK HERE FOR PISTONS AND SLEEVES
CLICK HERE FOR CONNECTING RODS
CLICK HERE FOR STROKER KITS
CLICK HERE FOR THRUST BEARINGS
CLICK HERE FOR TOOLS
CAMSHAFTS!
Brian Crower Stage 3 280 Camshafts Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth Camshafts MX1 Grind Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Brian Crower Stage 2 272 Camshafts Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
GSC Power-Division Camshafts S2 Grind Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
GSC Power-Division Camshafts S1 Grind Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
HEAD GASKETS!
Cosworth High Performance Head Gasket 1.3mm Thick Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth High Performance Head Gasket 1.1mm Thick Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING
Cosworth High Performance Head Gasket 1.3mm Thick 90mm Bore Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
ROD BEARINGS!
ACL Race Rod Bearings .001 Undersized Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
ACL Race Rod Bearings Standard Size Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth Rod Bearing Set Size 0 Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth Rod Bearing Set Size 1 Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CLICK HERE FOR MAIN BEARINGS!
ACL Race Main Bearings Standard Size Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth Main Bearing Set Size 0 Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
ACL Race Main Bearings .001 Undersized Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth Main Bearing Set Size 1 Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Valve Guides and Retainers!
Tomei Phosphorus Bronze Valve Guides Mitsubishi EVO X 2008-2014 / Hyundai Genesis Coupe 2.0T 2010-2013 CLICK HERE FOR PRICING!
Tomei Titanium Valve Spring Retainers Mitsubishi EVO X 2008-2014 / Hyundai Genesis Coupe 2.0T 2010-2013 CLICK HERE FOR PRICING!
GSC Power-Division Intake Valve Guides Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
GSC Power-Division Exhaust Valve Guides Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
VALVE SPRINGS!
GSC Power-Division Single Beehive Valve Spring Set w/ Titanium Retainers Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Tomei High Performance Valve Spring Set Mitsubishi EVO X 2008-2014 / Hyundai Genesis Coupe 2.0T 2010-2013 CLICK HERE FOR PRICING!
Brian Crower Single Spring / Titanium Retainer Kit Mitsubishi 4B11T EVO X 2008-2011 CLICK HERE FOR PRICING!
Cosworth High RPM Valve Springs Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
[IMG][/IMG]
[IMG][/IMG]
PISTONS AND SLEEVES!
Darton Iron MID Wet Sleeves Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 86.5mm Bore 10:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 87mm Bore 10:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 86.5mm Bore 9:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 86mm Bore 10:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 87mm Bore 9:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 86mm Bore 9:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
