{******BOLT ON UPGRADE Garret turbos by ATP turbo******}
Garrett Dual Ball Bearing Twin-scroll GT3071R Bolt-on Turbo Kit, EVO X
Model Years: 2008 +
Engine: 2.0L 4B11 Turbocharged Inline 4
The Garrett® Evo X Turbo Upgrade allows you to push your AWD, rally-bred monster up to an estimated 475 HP with the Garrett® GT3071R (PN 788550-1) or a tire-smoking estimated 525 HP with the Garrett® GT3076R (PN 788550-2). Each turbo has been meticulously designed to be a bolt-on upgrade with no fabrication, cutting or welding required.
The Garrett® Evo X Turbo Upgrade features a specially designed twin-scroll turbine housing that mates up directly to the Evo X's stock exhaust manifold as well as the stock exhaust down pipe to allow for aftermarket exhausts to be used without worrying about fitment.
The turbine housing allows for the retention of the stock exhaust heat shield for better temperature control as well as a stealth look.
The ported shroud compressor housing reduces the occurrence of surge during operation and mates directly to the intake piping as well as the stock outlet position.
The Garrett® patented dual ball bearing center housing is standard on both turbocharger options for unmatched power handling and unbeatable response.
The Garrett® Evo X Turbo Upgrade is a powerful, yet highly streetable enhancement to an already potent car.
GT3071R
PN 788550-1
Horsepower (estimated) 475
Compressor Wheel Inducer 53.1mm
Compressor Wheel Exducer 71.0mm
Compressor Wheel Trim 56
Compressor Housing A/R 0.60
Turbine Wheel Diameter 60.0mm
Turbine Housing A/R 0.73
Kit Contains:
* Garrett® GT3071R (PN 788550-1) dual ball bearing application specific turbocharger
* Inlet elbow
* Oil drain line
* Water lines
* Gaskets and necessary hardware
* Installation Instructions
GT3071R
PN 788550-1
Kit Contains:
* Inlet elbow
* Oil drain line
* Water lines
Garrett Dual Ball Bearing Twin-scroll GT3076R Bolt-on Turbo Kit, EVO X
Model Years: 2008 +
1/4 mile time: 11.7 ET with best trap speed of 125.7 MPH
In full 100% factory weight
GT3076R
PN 788550-2
Horsepower (estimated) 525
Compressor Wheel Inducer 57.0mm
Compressor Wheel Exducer 76.2mm
Turbine Housing A/R 0.94
Kit Contains:
* Garrett® GT3076R (788550-2) dual ball bearing application specific turbocharger
* Inlet elbow
* Oil drain line
* Water lines
PM me for pricing guys!!
Dan@Assaultech
EvoX 'For Sale' External Engine / Power
54
Jul 15, 2013 09:05 AM
SBR INC
Vendor Classifieds
37
Sep 20, 2011 11:57 AM
ETS Michael
ExtremeTurboSystems.com – WA
Dec 23, 2009 10:44 PM
Chris@nolimitmotors
23
Oct 19, 2009 02:56 PM
PeakBoost
May 1, 2009 01:52 AM
