TopSpeedAutosport | Megan Street Series Coilovers in-stock!! Ready to ship!!
TopSpeedAutosport | Megan Street & Track Series Coilovers in-stock!! Ready to ship!!
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts with Front Camber Plates
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
- Rubber Dust Boots
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All Hardware is Included
$829 Shipped
APPLICATION:
Mitsubishi Lancer EVOLUTION 8/9
SPRING RATES:
F: 62mm ID; 200mm length; 7 kg/mm
R: 62mm ID; 220mm length; 8 kg/mm
DAMPER SPECS:
F: 120mm stroke; 280mm length; M2 valving code
R: 135mm stroke; 300mm length; A11 valving code
$829 Shipped
APPLICATION:
Mitsubishi Lancer EVOLUTION X 2008+
SPRING RATES:
F: 62mm ID; 200mm length; 8 kg/mm
DAMPER SPECS:
R: 135mm stroke; 340mm length; A1 valving code
Megan Track Series Coilovers
$829 Shipped
APPLICATION:
Mitsubishi Lancer EVOLUTION 8/9 2003-2007
SPRING RATES:
F: 62mm ID; 180mm length; 12 kg/mm
R: 62mm ID; 150mm length; 10 kg/mm
DAMPER SPECS:
F: 120mm stroke; 280mm length; M3 X valving code
R: 135mm stroke; 280mm length; A1X valving code
$829 Shipped
APPLICATION:
SPRING RATES:
F: 62mm ID; 200mm length; 12 kg/mm
R: 62mm ID; 220mm length; 10 kg/mm
DAMPER SPECS:
F: 120mm stroke; 280mm length; M3 valving code
R: 135mm stroke; 340mm length; A1+ X valving code
SPRING RATES:
DAMPER SPECS:
Please feel free to PM us if you have any questions!!
