GTWORX Tarmac Sport Springs REINTRO special!!!
We also have a few package deals with the springs if you want to add some bushings or swaybars.
$339 SHIPPED
300 lbs/in rates front and rear
Functional drop of 1.2 inches front and 1.0 rear
We set out to offer an effective "coilover alternative" for the EVO X. A spring that actually improves handling, and doesn't just drop the car, while maintaining good ride quality. Function first, with a drop that looks great too! These are THE handling spring for the EVO X!
Turn in response is greatly improved. The top heavy feeling of the stock car with stock springs is gone! Now you feel as though the chassis is working with the rest of the car. The power feels good with the suspension where as before you felt like.....there isnt enough suspension for the power level and if modded...forget it !
$339 SHIPPED
GTWORX Tarmac Package 1
GTWORX Springs
Whiteline adjustable rear swaybar
$479 shipped!
GTWORX Tarmac Package 2
GTWORX Springs
Whiteline front roll center kit
$687 shipped!
^ This is our most popular package...a great to step up your suspension to a level that looks good, handles great, and won't beat you up. A good all around package that lets you dial the balance to your liking with the adjustable rear swaybar.
GTWORX Tarmac Package 3
GTWORX Springs
Whiteline adjustable front swaybar
Whiteline front control arm bushing
$749 shipped!
GTWORX Springs
$479 shipped!
GTWORX Springs
$687 shipped!
GTWORX Springs
$749 shipped!
Ohlins DFV Coilovers
These were improved over the older version with better valving and better build quality.
Includes front camber plates and rear pillowball mounts
dual height adjustable
Rebound adjustable with improved Dual Flow Valve technology for awesome handling and ride quality.
We can work with you to help you dial in ride height, alignment, and damper settings for the street and track.
SALE price of
$3595 with custom rates
This is with custom 10k/10k spring rates. You really should avoid the standard spring rates.
SALE price of
Finally a new coilover option at a realistic price, that doesn't suck! Awesome euro valving, tons of suspension travel, great USA support, great build quality, and a proven track record (used on the 2009 Redline Time Attack Street champion car).
Monotube, single damping adjustable, with Swift OR Hyperco coilover springs depending on stock.
All sets are CUSTOM sprung....we can work with you on a desired spring rate to match your car and driving style.
$2399
This price includes custom spring rates and helper springs at all 4 corners.
Avoid the too much rebound, not enough compression damping, poor quality springs, clueless tech support, non-existent suspension travel, coilovers that are so widespread out there....and get something that WORKS!
$2399
Whiteline Roll Center Kit
Lower the car a little more without screwing up suspension geometry. Improve suspension geometry on the stock suspension if you like. Less roll, better camber curve. MORE GRIP.
$215 shipped
Whiteline Rear swaybar
Add front grip, helping to reduce understeer and improve the balance of the car. More overall grip, less roll.
$197 shipped
Whiteline Front swaybar
Add rear grip, reduces rear wheel lift in tight corners, improves turn in. More overall grip, less roll.
$191 shipped
Get both front and rear Whiteline Swaybars for $379 shipped.
reduces the sloppy rubber bushings that comes OEM. No more dynamic alignment changes while cornering, better control, more grip.
$89 shipped
$215 shipped
$197 shipped
$191 shipped
$89 shipped
GTWORX Springs
Did you mean rear and front with this package?
GTWORX Springs
