GM map sensor w/pigtail
im selling because i have the txs map sensor. im not 100% sure what else you need. i know jack could help with that. let me know, i have everything boxed up and ready to ship.
Yeah you can pick up the molex connector and crimps from www.mouser.com (the part numbers are in the appendix of the UTEC manual v1.7 that you can download from turboxs)
Or if you have an older computer power supply, there's an ATX+12 power supply used on some systems that have a square 4 pin molex connector, that is the same connector as the part you need. Some computer stores also sell an adapter to adapt the rectangular 4 pin molex to this square molex connector.. If you buy the adapter, you can use just the square part and cut off the other part....
www.startech.com makes this, its part is called "6 inch LP4 to P4 power adapter" part number LP4P4ADAP just cut off the LP4 (rectangular connector) costs $2 or less..
evoxsi
Sep 29, 2014 01:07 PM
sgplancer
Apr 19, 2006 01:34 PM
BSREVOLUTION
Apr 30, 2005 09:23 PM
