FC Datalogit
FC Datalogit
Any one Try the FC Datalogit and how is the unit compatible with the PowerFC. Please comment on what are the Good stuff that you feel about this unit and what are not...
any comment are welcome...
Pretty much plug and play, had a few problems getting it to connect the first time, but then figured it out myself. The aftersales isn't very good.
But the unit and ease of use do more than make up for this.
I use it, never used anything else with the power FC but its awesome.
Do you do the tunning on the Dyno or On Road?. The FC can display Knock how usefull is that when you install and tune?
it display any error when the sensor have problem...?.
have a read of the power fc faq
http://paulr33.skylinesaustralia.com...owerfc-faq.htm
it covers datalogit in detail and its use
It displays knock in the same grid that your fuel tables and ignition tables are, the only smallest of small niggles is that its in a different window, so you find yourself flicking from screen to screen(you'l notice this when you get it, probably won't know what i mean now)
Anyway, basically it logs everything you want, from knock to my most useful wideband reading, you can connect your innovate LC1 straight to the box, couple of quick calibration settings to change and you have a full logging system of everything you want.
I rate it very highly, the Power FC isn't seen my many as the best ECU, but for its versitality and with the addition of dataloggit, i can't see me changing mine any time soon.
Location: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
FC Datalogit is a great tool. It is the easiest way to tune the PFC, short of having the Power Accel (sp?) software. I recently switched to the new Universal version of the software and like it even more.
Map Watch mentioned above is one of my favorite features. You can log any sensor, including knock and your wide band, in the 20 x 20 grid. You know exactly what cell is giving you knock or running too lean/ rich.
I use both the dyno and road for tuning. It was set up on the dyno and then fine tuned on the road. I really prefer to do the drivability (low load cells) tuning on the road and only fine tune the high load cells on the road.
Whats this other software, i.e. where can i get it from?
clip14
Jul 14, 2016 04:34 PM
gavi101
Dec 12, 2013 02:37 PM
tunermt
Aug 8, 2011 12:27 AM
Miralution
Dec 19, 2006 03:33 AM
