Multiple Maps with Power FC?
Old Mar 20, 2008, 08:48 PM
h22gordo's Avatar
Is there a way to store more than 1 map with the Power FC?
Would FC Datalogit be a solution? Or do I need to buy another Power FC without commander and hook it up to a switch?
I need another map.
Thanks for the help.
Old Mar 20, 2008, 10:07 PM
NTICEN's Avatar
only way that i know is to use a datalogit to change the maps as you go
maybe you could use a palm running the datalogit software for ease to change maps?
Old Mar 25, 2008, 07:47 PM
h22gordo's Avatar
Anyone else have any ideas?
The Palm might be an alternative, but looking to see if there is a solution where it can easily be switched from Map #1 to Map #2 without having to whip the laptop out.
Basically want to be able to switch maps on the Fly. Is this at all possible?
TIA
Old Mar 26, 2008, 05:55 AM
paulr33's Avatar
there is more than one way to acheive the goal
thinking aside - why do u want to switch between maps? for what purpose
Old Apr 1, 2008, 03:04 PM
h22gordo's Avatar
Hello Paul,
I'm constantly switching from 91 octane (for daily driving duties), to 100-110 octane for racing.
I want to be able to switch maps quickly (after I fill up a tank full of 110 octane, don't feel like pulling the laptop out to start tinkering with a new tune)
Just looking for a simple, quick solution to be able to switch from 1 map to the other without having to do too much work.
Old Apr 1, 2008, 09:30 PM
EvoVIII808's Avatar
i was looking on here a bit ago, and there is a way to switch with the stock ecu. But with the Power FC, just save the map, and put it in once you switch over. Besides that, there is no way to just switch over.
Fas4dr
21
Jul 28, 2016 04:22 PM
clip14
Jul 14, 2016 04:34 PM
David Buschur
Apr 20, 2012 07:59 AM
Rui Evo
Jun 15, 2006 02:17 AM
pyrovice
Mar 31, 2005 04:56 PM
Quick Reply: Multiple Maps with Power FC?
