What is the Advantages of Standalone Ecu vs Evo Oem Ecu?
Hi Guys,
just wonder "What is the Advantages of Standalone Ecu (Haltech/Microtech) vs Evo Oem Ecu?" beside its Anti-Lag, SD & LC Features?
Thanks
Thanks
with a stand alone you will have more fail safes, plus a lot more features to play with that may or may not be needed. Plus with the haltech which is what I will run here soon you have flex fuel options. Sure you can do it with the stock ecu, but its fairly new. I rather use something that has been doing it for a while and gotten all the bugs worked out of it personally. Another thing is you have more definition in the fuel and timing maps then you will with a stock ecu.
By using standalone ecu, do we still need to adjust the latency table for any aftermarket injectors, Maf Scaling and by the same tune map (Fuel & Timing) the standalone ecu will get the car more responsive?
Not a problem, there will be setup maps where you have wizards to select your injectors, mas or map, wideband etc and it will create a base map. From there you would just go in and adjust everything as needed into the map as you would in the stock ecu. But to answer your question yes you may have to. But like I said you will start out with a wizard to create basically a start up map rather than having to fiddle around with things right away.
I'd say the evo software has _way_ more routines/corrections/filters to ensure a failsafe operation and much more advanced knock detection/prevention and limp-mode than any aftermarket ECU. Also idle control on OEM softwares is way ahead of any idle control i've seen on any AEM, haltech or gems ECU which often idle like a tractor even on mildly modified engines where a stock ECU can idle just as smooth as on a stock engine...
For a road car there's no real point in running an aftermarket ECU - for racing engines there might be some features not covered by the varios mods and/or tephramod that make it worth to switch to an aftermarket ECU (hard anti-lag). Also when tuning for the last bit of power no correction overhead might be desirable, but only if you can assure a given fuel quality (=race fuel). Again: for a road car the oem software is way more safe.
A MAF based system is the most accurate way to control fueling since it measures the mass of the airflow coming into the engine instead of calculating it based on RPM, manifold pressure, air temps, VE tables etc. With a MAF system atmospheric variations are taken care of by the MAF. With that said even though you might be seeing your target AFR with your wideband it might still be running rich.
I would highly recommend to use a GM slot style MAF and position your IAT sensor before the throttle body or better yet right after it inside the plenum.
Blitz_b9
11
Aug 16, 2016 03:11 PM
Blitz_b9
May 21, 2012 10:18 AM
gunnerman
10
Oct 31, 2005 05:00 PM
MalibuJack
33
May 29, 2005 05:41 PM
